Hi all,
I measured my valve stem/guide wear and it's well out - e.g. 1-1.5mm egg. The manual says that the guides cannot be replaced but I've seen a couple of threads on here with folks discussing replacing the guides e.g. http://www.audizine.com/forum/showth...9-jhm-hd-heads
Can the guides be replaced with off-the-shelf guides? Obviously anything can ultimately be machined but I wanted to check whether these heads can/are routinely have the guides replaced?
I'm aware that JHM do it per their website but wanted to double-check that this is a capability that other shops have done and with off-the-shelf guides.
I'm also assuming that the valves will also need replacing but the manual doesn't give the specs for the valve stem for me to check.
Cheers,
Neil.
