Results 1 to 6 of 6
    Sep 02 2008
    Boonies VA
    Sail Panel Removal
    Does anyone know how to remove the sail panel from the front doors? I am assuming it just clips on there, but don't want to yank on the thing and break it.
    White Wagon
    May 20 2010
    Sail panel?
    Oh, should've researched first. I've never removed it, but I imagine that it would have to clip on somehow because there are no screw holes that I'm aware of. I'm sure if you did bust it, you could find another one pretty readily.
    Nov 15 2011
    Montreal | I sell in USD
    Click here
    The trims are just cliped, pull toward the rear carefully, for the rest its above. The one in the door jam, pull towards you starting from the bottom.
    *****I sell in USD*****
    May 20 2010
    Isn't the sail panel the one in the corner, on the other side of the mirror (inside rather than outside)?
    Nov 15 2011
    The other side of the mirror = the one in the door jam. Start pulling towards you from the bottom. (Right in the picture below)
    The one on the inside of the window frame, you pull towards the rear of the car. (Left in the picture below)
    Edit : I thought I linked the window frame removal where we see these being taken out but I linked the door card removal, I'll fix this.
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by Axis View Post
    Was wondering what your original link had to do with it, thanks!! Looks simple enough, I am just planning to remove the ones on the inside of the window frame.
    White Wagon
