Results 1 to 25 of 25
    Active Member Two Rings happy187's Avatar
    Dec 14 2006
    Houston, TX
    5 days after purchase...in the shop
    Just purchased a pre-owned S4 form my local audi dealer. 5 days later on the way home my A/C wouldn't get cold and then my temp gauge went through the roof. Limped home stopping every 2-3 minutes, let the car cool and then drive for 3-5 minutes as the temp climbed up again.
    I assume its the thermostat, I'll find out tomorrow. At least the dealer agreed to give me a loaner despite there policy to not issue loaners to pre-owned repairs.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    specs on the car?
    2010-2011 etc? and yes its probably the t-stat, but the ac might be a separate issue...
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Dec 14 2006
    Houston, TX
    2011 74k auto no mods
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    Yup just the thermostat. Had the same thing happen to me when I purchased my 2012 S4 with only 23K on her. Barely made it to the first off ramp before the temps climbed through the roof. Called the dealer, they flat bedded it to the Audi dealer across the street and then gave me a loaner, they handled it. Sucked for the dealer cause I drove two hours to get to them and told them once they fix it they can deliver my car back to me and then they can have their loaner back. Took them a week.
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Is the Thermostat issue more of a B8 problem or did it carry over to the B8.5?
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by happy187 View Post
    Did you get the message "PULL OVER AND TURN OF ENGINE NOW!"? I got that message when my tstat died. Not a happy message to get. I couldn't help but read it in Jezza's German-imitation voice.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Thats a new one for me, I have a 2013 CPO and part of the CPO is getting a loaner anytime the car is in the dealer.
    Might want to check up on that.........
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    Quote Originally Posted by bmoreS4 View Post
    Same for me - 2014 CPO and the dealer has always given me a loaner on questions asked (I didn't purchase from them either).
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    OP just said pre-owned, not sure if it was CPO in order to get a loaner everytime. But I'd hate having an issue like that and not getting a loaner. My TSTAT also went out like this. I think I was at 39k.
    Sent from my SM-G900V using Tapatalk
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Quote Originally Posted by GRUMPY-S4 View Post
    Would like to know as well!
    Murdered B8.5 S4
    Build Thread
    Nov 16 2015
    DFW
    Quote Originally Posted by silverf0x View Post
    My local buddy Jran76 told me that its mostly a B8 thing as it was changed to metal on or about the 2012 MY
    Apr 04 2012
    MSP
    I'm surprised dealerships are selling pre-owned B8's without updated T-Stats...
    You should get a free loaner from the dealership you bought the car - heck from any Audi dealership... you bought an Audi and should expect that level of service...
    Jan 05 2015
    Boston
    It's definitely more a problem in the B8. Has anyone gotten this replaced before it's failed so it doesn't inconveniently fail on you like it seems like it does for most people (i.e. random driving, driving to work, etc.). Just curious if dealers are willing to replace this before it fails. I guess it could depend on the relationship you have with the dealer/SA.
    |2011 B8 S4 | AWE Touring w/ Non-Res Downpipes | APR Stage 2 Tune | APR Stage 1+2 Intake | KW V1 Coilovers | 034 Rear Sway Bar/Endlinks | 034 Transmission Mount | Eurocode Alu Kreuz | Apikol Rear Diff Insert | 35% F1 Pinnacle Tint | Hardwired V1 | P3 Gauge | BFI Alcantara Shift Knob | RS Grille | Adam's Rotors w/ Akebono Pads | HRE FF01 19x9.5 et45 /w PS4S 255/35/19|
    Mar 21 2015
    There are a few extensive threads on this matter. Search around a bit.
    Nov 16 2015
    DFW
    Was that for me?
    Mar 21 2015
    Was that for me?
    For everyone's sake, lol
    Nov 16 2015
    DFW
    You are persistent...
    Apr 04 2012
    MSP
    Quote Originally Posted by Davido1 View Post
    Yes.
    There's a fuel rail recall on the B8 (11's and 12's perhaps some 13's also) and they are pro-actively replacing the thermostats at the same time... Mine was done last year.
    Jan 02 2014
    Halifax
    To replace before failure but with knowledge of failure, wouldn't that be considered a recall?
    Jan 05 2015
    Boston
    My VIN wasnt on the list for the fuel rail recall, guess I'll have to call the dealer and ask about the thermostat.
    Nov 16 2015
    DFW
    Quote Originally Posted by iceman42 View Post
    Im surprised they haven't done a recall on that! Plastic??? Really????
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I don't see how it can only be a B8 problem if people have reported them failing a second time after replacement? The updated thermostat part # is the same for all years. 06E121111AL. I think that all years are susceptible, with the B8s just being more prone to earlier failure. Bottom line: be prepared for it to happen sometime during ownership.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    It is a problem for all years, and even the newer revision of the thermostat will fail. All the thermostats are plastic, they never changed that. It is the waterpump that changed from a plastic to a metal body, after 2010.
    Apr 27 2011
    MD
    where did you check your VIN?
    IG: @s4dad
    Jan 05 2015
    Boston
    http://web.audiusa.com/recall/#
