Results 1 to 28 of 28
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Simple mod for those wanting to improve stock air box
    I just added the Spulen turbo inlet hose. It's larger in diameter and gets rid of the crisply accordion plastic inlet hose.
    Stock vs Spulen
    Installed on the car
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Does it have a flex point in it anywhere, that's the point of the accordion part in the stock piece.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Aug 28 2013
    Quote Originally Posted by aaronz View Post
    There is plenty of play in the intake. The airbox moves when pushed and pulled on the hose.
    Account Terminated Four Rings
    Sep 13 2014
    New York
    Just saw the thread. Thanks.
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    Have you modified the intake pickup area yet. I opened up the blocked section directly in front of the air box on top of the core support. I don't know if it makes any power but I could hear the difference. I also pulled out the snow screen section.
    Sep 13 2014
    New York
    Just doing a lot of R&D. Getting my car Friday. I'm looking at apr hose kit. Turbo muffler delete. Diverted valve upgrade. Temped by apr but a piggyback is better for warranty if they can be installed easy.
    Aug 28 2013
    Quote Originally Posted by Z32drifter View Post
    Not yet. I will be looking into that as well. I live in the north where we have snow, so, I am not sure that's a good idea. I might get a ton crud on the K&N filter.
    Sep 13 2014
    New York
    Just ordered spulen hose and kn air filter.
    Sep 13 2014
    New York
    Installed kn filter and removed rain tray in bottom of air box. Still waiting on hose. Car is definitely more responsive. When I install hose will also be doing Go fast bits diverter valve. Then tune if available
    Aug 28 2013
    Quote Originally Posted by Jimmy ny View Post
    That's exactly what experienced. I recently removed the rain tray and added the Revo Carbon fiber intake scoop as well as the Spulen silicone intake tube and K&N and the car is world of difference over the stock car with APR stage 1 ECU and TCU tune.
    Sep 13 2014
    New York
    Quote Originally Posted by Baggio View Post
    How do you like apr stage 1?
    Aug 28 2013
    I love the tune. It's freaking fast now. The DSG tune makes driving it better as well. "D" mode is actually more usable than stock. In Sport mode it pulls like a freight train. APR intercooler is ordered and I will eventually get a downpipe and go Stage 2.
    Sep 13 2014
    New York
    I ordered the go fast bits diverter valve +. APR doesn't support my ecu yet. Hopefully in a few weeks. Will put spulen hose on tomorrow.
    Sep 13 2014
    New York
    Tune is in. Ordered afe intake. My Installer didn't recommend changing the valve. So I returned it. 034 dog bone mount up next. Down line the intercooler.
    Aug 28 2013
    Did you go with APR tune? Did you get a DSG tune as well? How do you like it so far?
    Sep 13 2014
    New York
    Apr stage 1 high torque. Every time I drive it feels faster. D in dynamic is quick. S in dynamic is nice but I feel I need this dogbone insert. I'm not going to do dsg tune.
    Aug 28 2013
    With the APR stage 1 high torque tune, your DSG may start to slip without the DSG tune. More slipping = more heat = more wear on the transmission. Just an FYI... Have fun with your tune.
    Jun 10 2008
    Spiders
    Chicago And NJ
    Don't trust everything you read on the Internet
    Sep 13 2014
    New York
    Really? Haven't heard of that before. I heard high torque tune was a concern for other platforms with a manual transmission.
    Sep 13 2014
    New York
    20 lb difference should not be a concern. Not drag racing the car.
    Aug 28 2013
    Not saying it is going to happen. But others have experienced it, hence the low torque option.
    Sep 13 2014
    New York
    Personally I think transmission tuning is just another add on. For tuners to make money.
    Aug 28 2013
    World of difference driving in D mode. That's for sure. It doesn't shift to 6 th by 40 and downshifts properly based on throttle for acceleration. It keeps it in the powerband, yet still gets good gas mileage. Then adds extra clamping power for the high torque shifts. The ecu tune gives power/torque, but the DSG tune gives better overall drivability. If transmissions weren't slipping they would only have the high torque tune.
    Sep 13 2014
    New York
    Well I think it's only an add on. These so called transmission tunes only came about recently. It also only seems to be a Audi/Vag thing.
    Jun 10 2008
    Spiders
    Chicago And NJ
    It for sure has its benefits but not needed with this transmission at these levels, the options are for the 6sp folks more than us.
    Jun 10 2008
    Spiders
    Chicago And NJ
    Edit: not needed to use the high trq option, could for sure be used for the additional benefits it has
    Aug 28 2013
    Audi/Vag seems to have the most neutered throttle response I have experienced in D mode from automatic transmission from other manufacturers. Then the shifts are like at 2200 rpms.
    Aug 28 2013
    I did it for the shift points and throttle response in D mode. Extra clamping is an extra benefit, imo.
