Results 1 to 4 of 4
    Jan 19 2014
    2 Victory motorcyles, 1 Triumph motorcycle. Volvo 850 Wagon.
    Nashville, TN
    Small window seal air leak
    I have an -09 A5 Coupe, 3.2 Automatic with 82,500 miles on it. Just the other day I started having a tiny bit more wind noise at the passenger door seal. Is it normal for the rubber to dry out and not seal correctly, or is it a thing where the door hinges or window positioning might be slightly off from wear and tear? I am appreciative for any help.
    2009 A5, S-line
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Interested to hear if anyone has a solution to this as well. I've been experiencing the same issue since I bought my car at 29k miles.
    To add to your description, my noise is most noticeable when the roads are wet.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Established Member Two Rings ap610's Avatar
    May 24 2014
    Atlanta
    Try applying silicone spray to the rubber seals and see if that takes care of it.
    http://www.amazon.com/Permatex-80070.../dp/B000HBM5S2
    Probably better to spray on a rag and wiping instead of spraying directly on the seal.
    The Safelite guy who replaced my windshield on my other car noticed my Audi in the garage and said when the rubber seals go bad on my A4 (and they definitely will)--try silicone spray.
    Jun 03 2012
    Phoenix
    Another suggestion is Zymol Seal.
    http://www.amazon.com/Zymol-Seal-sof.../dp/B003ANPY8C
