Results 1 to 11 of 11
    Oct 26 2015
    Norman/OK
    2016 SQ5 reverse lights
    So I ordered a set of brighter LED reverse lights. Went to the manual and Audi was nice enough to say you have to take the vehicle to the dealer as there are no end user serviceable bulbs on the SQ5. Anyone know if there is a way to get to the reverse lights without having to remove the rear facia?
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    I looked into this before and found this at the time.
    Reverse Light Replacement Audi Q5
    I haven't done it yet, but it looks pretty straightforward to pull out that light assembly.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Oct 26 2015
    Norman/OK
    Yep, that helps. Thank you.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Don't you get a little pissed that Audi thinks you're to stupid to replace a bulb?
    Better take it to the stealership and give up around $50. Jeez...
    Jul 06 2015
    Odivelas, Portugal
    I did this on my Q5 and is pretty easy ! Audi thinks we are all stupid and dumb !!!
    Senior Member Three Rings turrifik's Avatar
    Mar 08 2015
    Are the LED lights brighter? Where did you get them?
    Mar 26 2015
    New York, NY
    Philips 921 White Vision LED Back-up light (Pack of 2) https://www.amazon.com/dp/B00P2D41OQ..._Hnffxb1G2068B
    Current
    Past
    Established Member Two Rings SQ5LIFE's Avatar
    Feb 08 2016
    Barrington IL
    How much brighter is it? Worth it? Maybe some before and after pics guys?
    Oct 26 2015
    Norman/OK
    Well I got them swapped out, very easy as per the previous instructions. now the bad part is it only took 2 key cycles for them to trip the system that the bulbs are bad. So back to the drawing board, seems the bulbs will need to be CANBUS compatible in order to work.
    Mar 07 2004
    '14 Q5 TDI Prestige & '14 Q5 TDI Premium Plus
    Charleston, W.V.
    Do they affect the backup camera in the dark? I bought the brighter license plate LEDs for my Passat and can't see crap in the dark with the camera.
    Oct 26 2015
    Norman/OK
    My hope was they would be brighter than the stock ones, wont be able to see now since they are tripping the light on the dash. They are coming out later today.
