    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    For those with an extended HPFP hose (Barb fitting)
    What size is the hose? How many PSI run through that? I dont wanna get second guess this as id like to convert to studs.
    Thanks you
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Dec 23 2011
    On mobile but my guess is you are asking about the barb fitting which is the low pressure fuel input to the hpfp. If so it's 5/16" ID. Low pressure fuel system is 5-6 bar or about 70-85 psi. Don't buy hose from autozone, it will burst. I use Gates Barricade mpi fuel injection hose, rated to 225 psi working pressure.
    Dec 04 2011
    Kansas City, KS
    Thank you, and yes thats the hose im talking about, i just wasnt sure if i needed to withstand 1700 psi or 100. I know the factory one is reinforced.
    Thanks
    Mar 24 2013
    Oakdale, CT
    I know VAG has made some engineering blunders, but I doubt even they would intentionally put gasoline at 110 bar through a rubber hose.
    You can find the hose you need at NAPA. Just tell them what you are using it for and what kind of pressure it will see.
    -Adam
    Dec 04 2011
    Kansas City, KS
    You never know with VAG cars these days. I just wanted to make sure. Thanks Adam
