I was doing a few spirited pulls last night and all of a sudden the battery light comes on. Shortly after that, the whole cluster lights up and everything freezes. The speedo, tach, all the guages a frozen, the CEL is on as well as most of the other warning lights, and the brake like is flashing. I quickly pull over and power down, and fortunately the gauges reset.
I start it back up and everything is normal. After about five seconds the battery light is back on, and I see that it is pegged charging at 16v (the limit of the gauge). The car is running perfectly, but it seems to be overcharging so I make the short trip home and hope nothing burns up - the cluster locks up again. A few more restarts at home and the symptoms are always the same: volt meter goes to 12v after startup, then slowly climbs to 16v, then battery alarm goes off. This all takes about 10 seconds.
I've searched and found many threads on undercharging, just none on overcharging. I am guessing it is the voltage regulator since it is clearly charging. I don't want to replace the entire alternator as the regulator is much less expensive, but I know this is a 15 year old car.
Has anyone seen/solved a similar problem?
