Originally Posted by
emilio
how are they failing? electrically, in that they short, open, or otherwise cease to respond? mechanically, in that they take a current but don't move fluid for some reason? does the car otherwise run fine?
if they were failing mechanically i'd wonder about the integrity of the fuel tank and it's internal filter (i think these cars have tank screens). it could be that something is degrading and being swept into the pumps.
- emilio
Good question- the shop didn't specify if the failures have been mechanically or electrically. Previous symptoms for the fuel pump replacements have been the car failing to start, or, starting but engine sputtering erratically after starting and would die if I did play with the gas pedal. I then let the car sit and eventually it fired up and drove fine.
This weekend the engine sputtered while on the highway driving around 75 mph so I pulled off the freeway and the engine died while on the offramp but I was able to pop the clutch and it restarted, but then drove fine after that. The car started and drove fine this morning.
