Results 1 to 4 of 4
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Door removal/replacement
    Well after half of a year of ownership I managed to mess up my right rear passenger door bad. Was in a super tight space when suddenly I felt the car hit something and my heart sank. 99% of the damage is on the door and its smashed in pretty good. The rear dog arm took minor impact but only left some scratches and a tiny dent. After looking online I found a door in the same color from a totalled 2009 A4 for 300 dollars. The door itself has one minor scratch but nothing bad. After 180 dollars for shipping and 2 weeks I picked up the door and now the next step I need your guys help.
    There are already plenty of DIYs for interior trim removal but thats only half the battle. Im going to need to switch all the exterior trim, windows and interior over.
    My couple questions:
    Anyone pulled a door before off a B8? Is it a hard process?
    Air bags in rear doors?
    How do I transfer the exterior trim, electronics (harness?), windows.
    If anyone has any DIY door links that would help aswell.
    -I will try to upload some pictures later of my shitty door and the new one.
    Thanks Audizine
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    Weather tech laser fit mats
    110,XXX Miles
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    No airbag in the door. Removing/ installing the door is a bolt or two at each hinge, I think you need a metric triple-square bit. Two people to remove and install the door onto the car is a must. Trim, inside and out are all easily removed/replaced. May have to adjust the hinges and striker plate to get the door alignment tweaked-in.
    What is a "rear dog arm" ??
    Hopefully the paint color on the replacement door matches. Even the same paint color code can have batch variations from the factory....nevermind fading.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by S4'ed View Post
    Good point. Either way will probably look better than what he's got right now.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    do lambo doors!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
