Results 1 to 1 of 1
    Jan 24 2010
    Paramus,NJ USA
    B6 A4 Daily driver big turbo build need some input!!!
    So long story short my brother decided that it's time to build a motor for his car.
    So right now car is stock 2005 b6 a4 1.8t Amb Quattro 6 speed manual.
    Looking to go big turbo.Since I'll be doing all the work I could use some input from you guys.
    Realistic goal is around 400whp only because it looks like that's all the stock trans can take.
    So here's a list I came up with as far as parts go.
    Amb block
    Scat rods 20mm pins
    Aeb pistons
    South bend stage 3 clutch
    Aeb head
    Possibly cams we'll see
    040 pump
    630cc Siemens injectors
    Fmic
    High flow cat
    3" cat back
    Top mount turbo manifold either t3 or t4
    Borg Warner turbo s200sxe 52 or 57mm???
    Engine mounts
    Trans mounts
    S4 throttle body
    Aeb intake or custom
    So far that's all I got as far as the big stuff goes obviously new crank bearings and rods bearings and all new necessary gaskets head bolts among other things.
    My main concern is spool of the turbo and whether I should be lowering compression???ideally I would assume car will run 25+ psi of boost maybe 30+ not sure if it's possible looking for some answers.Comment below.
    Ziddy Autowerks
