Just have 2 questions for anyone with a tip that's running a K04 or bigger, whether on Unitronic, APR, JHM, Maestro, GIAC, UM, etc.
1) in your logs, what max RPM does your transmission shift at?
2) under spool up, what is your WGDC?
Since some tuners up the rev limit to 7,200 RPM (which is fine for manual vehicles, but the tip max shift point is limited to ~6,800 from my understanding), should the RPM limit for a tiptronic tune be increased or left alone? Reason I ask is in my case, sometimes it will shift smooth ~6,700, while once in a while it feels like it will cut almost all power and won't shift until ~6,900 almost. (no I don't always drive like this, but when passing on the highway I have noticed this)
In regards to the WGDC question, I'm running the standard Unitronic K04 RFD file (labelled Rev5) which seems to only request a max of 74.9% during spool up, whereas every other log I have seen from other tuners (and even Unitronic tunes for the MKV K04 / golf R, and every log I have from the prior rev file and all prior stages) shows the usual 99.6. I emailed Unitronic back in November asking about this, since I remember CanadianB7A4 (think that's right) said that a post (and a PM) that Unitronic limited the WGDC on the file because he was over boosting (and testing the new revision that now has increased timing vs the previous revision) and wonder if they just forgot to put it back to 99.6 after everything was completed.
Thanks guys
