Results 1 to 13 of 13
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    What is the application for this specfic tip I have?
    Fits a Gt2871r Elim, yet takes a 2.75" Maf housing.
    Gtrs?
    Dec 05 2007
    Pic? Isn't that stock sized maf?
    Feb 28 2005
    Tempe
    Yes, stock sized maf.
    Has Forge stamped on the front.
    Then if you flip it over it has Neuspeed ~embossed into the silicone mold on the bottom.
    Dec 05 2007
    Merge product (doubtful)? Knock off stamp goof (highly probable)?
    Forge Motorsports US distributer in Florida has pretty good customer service. Email them your inquiry and they should reply. But seems it is just an upgrade from the stock collapsible one under decent intake. The stamps are questionable, though.
    Stock turbo inlet hooks up to the eliminator adapters. Problem people had was they required a larger maf end, and that is when companies made 3" ones to cater to 3" OD housings.
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Sounds like this one no? But forge stamped over samco weird.
    http://www.audizine.com/forum/showth...-A4-1-8T)-SOLD
    Feb 28 2005
    Tempe
    Awh ^
    That's it, it's Samco (and Neuspeed), so it's for those using a large billet adapter.
    That be it. Unfortunately I need a 3" induction boot.
    Dec 05 2007
    If you have the space. 2.75" aluminum coupler with 2.75" to 3" silicone coupler on other end. And if you feel adventurous, which I know you do most times, measure as far back till it is no longer the same OD as the end where the maf would sit. Then do what was just mentioned.
    Won't look rigged if done right. If wanting to cut back, use a "sharp" bread knife. Nice even one way strokes with not much pressure (should work, as I have done this on a diff app not car related and different material. but...should work). Meaning, only cut with the knife in one direction. Once one stroke is done, lift knife slightly to return back to the position of your one way original stroke without cutting on your way there. Should come out looking like it came from the factory that way. Softer the one way stroke, cleaner the end result.
    Feb 28 2005
    Tempe
    Thanks, gonna replace it with a 3" induction boot.
    Who provides these? Google can be terrible for me at times, tried every key word and nothing.
    Dec 05 2007
    Weird, I just typed Samco in the Google search and this was at the top of the list
    http://www.samcosport.com/usa/
    Feb 28 2005
    Tempe
    For 3" Maf's?
    Those appear to be all ~normal.
    Dec 05 2007
    Oh, thought you wanted the Samco website. I never had a need for one, but I always liked the ER one. Reason being, it is aluminum and you can fit different sized housings. Comes at a price though, unless you can find it cheaper elsewhere.
    http://www.evolutionracewerks.com/catalog/51
    Feb 28 2005
    Tempe
    Thanks.
    Hmmm...can't do that one, that's too many components to attach the maf itself. I have to be able to plug the 3" maf directly into the silicone tip. I know there's a 3" silicone one out there.
    Jul 07 2009
    Socal/IE
    034
