Results 1 to 40 of 64
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    Inside of valve cover broken? Oil consumption Related.
    I wasn't really sure where to post this so i made a new thread. didnt want to bump a thread from a few years ago.
    Has anyone had any experience with a broken valve cover? Im ripping through oil like crazy, and i believe its come down to my valve cover having a crack in the interior covers and sucking oil out through the breather and out the exhaust.
    I pulled off the valve cover tonight and it looks cracked to me, but if someone with more experience could chime in that would be great. Really hoping replacing this will solve my issues so i don't need to do rings/seals.
    underside of valve cover before cleaning oil off. There looks to be a lot of oil, and residue crap where the arrows are pointing. along the side where the pcv is and between cyl 2&3.
    Closer look:
    After wiping residue off:
    Closer look between cyl 2&3.
    Veteran Member Three Rings RickB_7's Avatar
    Feb 26 2015
    Tacoma, WA
    This is what my valve cover looked like. I was going through quite a bit of oil too and a new valve cover fixed that issue.
    Senior Member Three Rings ajdre's Avatar
    Mar 27 2008
    2003 A4 1.8T (RIP), 1966 Mustang Convert.,2007 A4 2.0T
    Boston
    Yes-its sucking oil into the pcv system and is probably dropping the oil into your intercoolers. Replace the cover (bernardiaudiparts.com ~$275 delivered including the gasket and new bolts) and you'll also need to drain and clean the oil out of the intercoolers. Happened to mine a month after I bought it. Freaked out and finally figured it out when I punched the gas and a cloud of white smoke came out of the exhaust. Thought I was screwed but was relieved that I now have no oil loss for over a year. Was drinking a quart for every 600 miles. Poor design on the system....not a fan of plastic engine parts that disintegrate over the years. Keep us posted on the outcome.
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by RickB_7 View Post
    I took a screwdriver like you have to yours, and mine is flexing/lifting, although not quite as much as yours. Im gonna take in to the shop and check with my mechanic just to make sure. he may also have a replacement valve cover in stock.
    Quote Originally Posted by ajdre View Post
    I checked my intercooler piping a few months ago (was still experiencing heavy consumption back then) and they weren't filled with oil, they only had a little bit of residue in them. Wouldn't it be sucking it down into the breather and straight through the turbo? I will definitely update this as things go along.
    for the record: some info on the car:
    125,000kms/77,000 miles
    United motorsports stage 1 tune
    Apr intake and test pipe.
    Have already replaced:
    Breather x2,
    Diverter valve
    Pcv.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Will such a crack in the valve cover also give you a boost leak? Im chasing a boost leak and im sort of at a loss
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    replace it. and vent valve.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Dec 04 2011
    Kansas City, KS
    Is that for me or the OP ?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    The valve cover is part of Audis great engineering making it all plastic and using Elmers glue to piece it together. Shiro has a great writeup to the inner workings of the valve cover and I believe also explained how to fix a,broken one.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Quote Originally Posted by vvenom800tt View Post
    It will probably cause a small boost leak but more adversely it will also pressurize the crankcase. Not sure how much but the theory behind it makes sense. I would replace it and complete logs before and after to confirm these issues.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Nov 16 2006
    Skokie, IL
    For what the PCV does i feel like is the ultimate cause for these other type of failures from broken valve covers to leaky valve cover gaskets to oil in the plugs and misfires. What a $h*t design.
    Dec 04 2011
    Kansas City, KS
    Its a terrible design. i just wish a billet cover wast $400+
    i guess i'll have to save up for one now since a new revision oem one is like $250+
    Might as well fix it for good and get a pretty one
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I've had a slight boost leak as well and I'm pretty sure this is my culprit. I've been waiting til it warms up to worry about fixing it as it only seems to effect when I'm WOT (or trying to reach full boost).
    That being said, the boost leak is very slight and I wouldn't have noticed without a boost gauge (peak at ~18 vs normal ~21psi)
    There has also been a little more than normal oil in my IC piping, which also lead me to this conclusion. 90% sure it's not the turbo.
    Quote Originally Posted by Danaldson View Post
    I hope this solves it for you; I've seen several of your posts. Seems like you've been chasing it for a while.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Thank you for this thread Danaldson, I literally just replaced my VC on Saturday for the exact issue. However, I didnt replace it with a brand new one. A friend of mine (CleverA4name) replaced his with a billet cover so he gave me his old one. I figured it would work fine seeing as he wasn't suffering from consumption issues whatsoever.
    I noticed with BOTH VCs that the rear section was loose/flexing, so I'm not sure if thats normal. Let us know what your mechanic says about it.
    I replaced it anyway, cleaned out my intercoolers and will check it in a week or so. Fingers crossed.
    Im also seeing/hearing some engine knock under heavy load. I assumed it was from the oil being sucked through the intake? Not sure if you were having the same issue
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by JDillon15 View Post
    Yeah I've had this issue for about 6 months now. But now I'm trying to get to the bottom of it.
    Quote Originally Posted by Low and Behold View Post
    I'm not getting any knocking, I'm seeing a ton of smoke out the exhaust. Which my guess is that oil is getting dumped through the breather into the turbo.
    Brought in the valve cover today, and unfortunately he didn't have a replacement in stock, but he took a look and said the inner cover could be cracked. He plastic welded it up and epoxied it. told me to give it a shot And let him know.
    I'm just about to put it back on the car here, so I'll take it for a drive and I should know right away if I'm throwing smoke out the back. Will report back.
    Dec 04 2011
    Kansas City, KS
    I have a spare cover that i might double check and plastic weld just to be safe as potential temp fix, ive never looked under my original one (my car is on 05 with 191k on it)
    Feb 21 2015
    Rip City
    I might just take my old one to the dealer and compare it with a new one. I don't think that rear plate is supposed to lift/flex like that, yet both of my VCs do
    Aug 28 2014
    Calgary, Canada.
    Well I just put the car together and took it for a hard drive.
    The exhaust seems to smell less like burnt oil, and more like exhaust fumes. Good signs.
    I still saw some smoke out the back, but not nearly as much as before. Could be normal, or could just be cleaning out the turbo/breather/exhaust. I'll keep an eye on this.
    Boost seems to pull harder now (boost numbers haven't changed) but it's feels less clogged if that makes sense. Probly because there is less oil going through the turbo.
    On a side note, when the car backfires, it's MUCH louder than before. Not sure how loud backfires tend to be with a test pipe.
    I'll keep an eye on this for the next few days and update. Hope this solves the consumption.
    Jul 11 2014
    Chicago, IL
    If it does, I would probably replace the VC with one that doesn't have JB weld all over it... lol
    But that's just me.
    Aug 28 2014
    Calgary, Canada.
    But that's just me.
    It should hold up fine with the epoxy, but I am going to look at getting a billet aftermarket vc with a catch can. Any recommendations for aftermarket valve covers?
    Jan 24 2013
    Chicago
    IE
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by Denio24 View Post
    IE
    That's one of the only ones I could find, but I haven't seen any reviews of it.
    Dec 04 2011
    Kansas City, KS
    Get the IE but dont get it from them, its cheaper elsewhere. Just google it and find the cheapest place.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I may be way outdated here, but wasn't there an issue with the IE VC's on not having taps for after market CCs?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Dec 04 2011
    Kansas City, KS
    It just has the top hole for a 10an fitting i believe. Youll have to run your can to that and the other end to the breather port on top of the oil filter housing where the plastic ribbed tube usually goes down from the oem pcv valve
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Ahhh ok. I knew there was something a bit different. That's good then
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 28 2014
    Calgary, Canada.
    I'm not able to run the ie cover without a catch can am I?
    Dec 04 2011
    Kansas City, KS
    You can run it without a can i think, but youd just have to run a 10 an line from there into the port on top of the oil filter housing.
    I know the exterior diameter of the ribbed tube is 22mm. So you can get a silicone hose thats 22mm that will run to a 90º -10an to barb adapter thats 22mm or 7/8"
    Aug 28 2014
    Calgary, Canada.
    yeah that makes sense. I think i can use get this. right?
    Account Terminated Four Rings
    Jan 15 2016
    '08 A4 2.0 Avant 6MT S-Line Ti
    SoCal 626
    I personally wouldn't run that valve cover with the epoxy mickey mouse fix, I'd be afraid of that shit falling off and getting into my motor
    Dec 04 2011
    Kansas City, KS
    http://www.autosiliconehoses.com/sil...one-hoses.html
    i think the biggest -10an to barb youll find is 5/8" so you might need a hose that goes from 16mm to whatever the exterior diameter of the filter housing (which is 28mm)
    They dont have that reducing size. But maybe run a 16mm to 22mm from the fitting on the valve cover then a brass barb thats 7/8" on both sides and run a 22mm to 28mm to the oil filter housing. 22mm = 7/8"
    http://www.autosiliconehoses.com/sil...5-colours.html
    Mar 08 2015
    Alaska
    Looping the bottom breather into the vc port won't do anything, they are both cc vents. You must vent one or both to the atmosphere/ intake pipe for the system to function.
    Sent from my SM-G925I using Tapatalk
    Oct 24 2015
    Perth, WA
    And venting to atmosphere is illegal in some parts...
    My respray thread
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    ^^ Yes, it is a violation of federal law in the USA as well. Specifically the Federal Clean Air Acts of 1970 and 1977, and the amendments to the Federal Clean Air act of 1990. This would apply to PCV defeats, venting to the atmosphere, modifications of catalytic converters, use of cats that are not as efficient as OEM, and test pipes etc. for anyone that cares.
    Aug 28 2014
    Calgary, Canada.
    I'm in canada and yeah it's also illegal to vent to atmosphere. So in order to run the ie cover ide need the catch can setup as well.
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by 907DAVE View Post
    Then he can run an inline T fitting with a filter on it
    Aug 28 2014
    Calgary, Canada.
    Ill probably just pickup a catch can while I'm at it.
    Im 99% sure the broken valve cover was the source of my consumption. Im going to keep a close eye on it but i had a few friends follow me, and they didn't notice any smoke coming out the back. Very good signs
    Feb 21 2015
    Rip City
    Thats good news. Im still getting smoke/knocking at WOT, though it doesn't happen every time. I fear I may have gotten bad piston rings...
    Feb 24 2004
    Minneapolis
    Keep us posted. Some day when mine goes bad, I might just JB Weld it.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by mtroxel View Post
    will do forsure! I would probably just recomend plastic welding it. I am a little nervous that the epoxy may come off on mine, so thats why I'm going to go with the IE cover.
    Feb 24 2004
    Minneapolis
    What's an IE cover?
