Results 1 to 11 of 11
    Oct 31 2014
    San Diego
    Post What spacers do you have?
    Daily driving a 2010 A4 lowered on st coilovers and running 19x9.5 all around, profile 255/35/19.
    I want to get spacers to push the wheels out for a super flush look - vertically match the outer wheel profile with the fender and give the stance that's more noticeable and aggressive.
    Really want to find the right size, or sizes.
    Measuring from the tire profile to the inner fender lining, the front has 5/8 inch, or ~15m mm of space, and 1/2 inch for the rear, ~12mm clearance.
    I was set on 12.5mm front and 10mm rear, though are there any downsides of riding 2.5mm wider up front, given it is fwd.
    I thought of doing 10mm in the back because the inner fender lining is thicker than on the fronts, hoping it'll give the wider rear stance I'm looking for.
    What are your thoughts, spacer wise? Brand input would also be helpful, such as H&R and ECS. Or any description or photos of your setup. Thanks in advance.
    front 1
    front 2
    back 1
    https://c2.staticflickr.com/2/1500/2...fe3e97f4_b.jpg
    back 2
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    There are a few good threads on this already
    Sent from ....
    B8.5 S-line prestige
    #fourringarmy
    Oct 31 2014
    San Diego
    Links? I haven't found one that matches my specs
    Feb 26 2008
    none
    BALTIMORE
    What size spacers? Lowered B8 A4
    "Read" the threads and use the info and see how it applies
    First off....
    What's the et/offset of the wheels? -this is the most important detail next to width
    Then how low? Coilovers? Springs? --this more so applies to how ur tire will contact the inner well an outer (inner lip) of the qtr /fender.
    Spacers... H&r are my preference
    Then alignment? -u can use specs to get the fitment at stock specs for wear an handling or u can go all camber gang
    Let's start there
    Sent from ....
    #fourringarmy
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    Hey man, I know we were suppose to meet up. I will see how this week goes, maybe you can stop by the house, and you can try those 10mm spacers out. Or you could just drop by and grab them and try them out.
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    What's the offset of your wheels now? That will help a lot with determining what spacers you need
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Oct 31 2014
    San Diego
    I'm down to pick them up to try them on. Less work on your part.
    Oct 31 2014
    San Diego
    Quote Originally Posted by Chanman94 View Post
    et48, I believe.
    Source:
    http://www.nicheroadwheels.com/specs.cfm?id=3638
    Mar 20 2016
    Elmira, NY
    I personally like the ECS Spacers. I ran them on my old BMW for years without issue and currently have them on my A4 as well with no complaints. I have run the H&R's and they are great quality, but Ive always received great service from ECS and I feel their spacers are a great value. Cant go wrong with either IMO.
    As far as size goes, based on your numbers Id go with 12.5/10 or 10/10. You don't want to rub, but I also am not a fan of the sub 10mm spacers so Id stick with at least that width.
    Jun 09 2014
    Calgary, AB, Canada
    Quote Originally Posted by baku777 View Post
    Go with a 5mm all around if you want to be safe. 10mm may cause a tiny bit of rub, depending how low you are. Most people are running 9.5 et40 rub free, so you can use that as a reference.
    - Richard
    Nov 03 2007
    Hey man just text me tomorrow, plus remember I am running 275 30 on 19x10 40 offset on the rear with no rub. I think the 10mm will be perfect.
