Results 1 to 17 of 17
Thread: Ak vs F/R Sways
    Established Member Two Rings Tod's Avatar
    Jan 13 2016
    Nw burbs Chicago
    Ak vs F/R Sways
    Looking to upgrade a little suspension work this round. Already have a CR-15 installed. I've done the reading and both are DIY installs. Both are roughly the same cost with new bolts etc. Reviews are great on both. I know the Sways help with body roll and seems the AK Is a overall suspension/steering help. Can only do 1 this round and I'm struggling on which to order.
    Which one? Why?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2012 Prestige, TI package b8 S4
    Past fun,
    2008 SRT8 Jeep pwr 440 Blown by Vortech
    1996 Eclipse GSX bunch of crap
    1996 Slp SS 383 Blown by Vortech
    Jan 13 2016
    Nw burbs Chicago
    Guess I should add, car is sports diff non ads. Won't track it and is a daily a driver. I like to open it up on occasion when I'm able. Springs at the cost for install I've been quoted I'd rather just get coilovers at a later date and save the labor $$ and do it once
    Past fun,
    Mar 21 2015
    Sways first for the body roll and they help with feeling like your car is more planted. You'll have a much better experience getting them first. They are more noticeable then the AK.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Sways for sure! But the install of the Sways is harder.
    The Sways wont be as noticeable in terms of "feel" since you already have the CR15
    Jan 13 2016
    Nw burbs Chicago
    Well that's pretty much what I needed. The body roll kills me. Just feels floaty. The reviews are great on the AK so I was having a hard time. Plus a AK won't take longer than an hour. Sways looking at the DIY even tho a ton of them have broken links doesn't seem bad. Figure a good 3 hours or so.
    Thanks gents
    Past fun,
    Mar 21 2015
    ^ The front isn't bad, the rear you need to lower the exhaust.
    Jan 18 2015
    Quote Originally Posted by GRUMPY-S4 View Post
    Not sure how this makes sense. The sway bars control body roll. The cr15 stiffens the shock towers and does nothing for body roll. If anything, you're going to feel less lag between steering input and vehicle response with the cr15.
    Sway bars and chassis stiffening address different areas of vehicle dynamics. Eliminating the body roll is going to be a very noticeable improvement in handling. Slightly improved dynamic response is something most drivers won't even notice.
    Agree with 14s4 - sways will make a more noticeable improvement in handling than the AK.
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    Whatever you do, get the aftermarket end links with your sways. They make a bigger difference in and of themselves than you might think!
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Nov 16 2015
    DFW
    Quote Originally Posted by roadawg View Post
    I read that they are noisy though
    Mar 21 2015
    You can get ones that don't have the spherical bearings in them which is what I did. A lot cheaper too.
    Edit
    Heres what I got for the front and Moog makes some for the rear.
    https://www.europaparts.com/sway-bar...k0411317e.html
    Senior Member Two Rings A4SlineWA's Avatar
    Aug 05 2015
    WA
    I think this will be my next mod too. Coming from a GT-R the handeling on the S4 kills me. It feels like I'm on a boat even in Dynamic mode and I'm dropped on H&R sport springs. Any recommendation on brand?
    -RS4 Piano black grill -Stvbek Carbon Fiber Lip -19x10 Niche Targa wheels in Anthracite -20% -LED foglight and tail plate conversion -Inverted black/red supercharged badges -Interior LED lights -Solo Motorsports Stage II tune: APR pulley, belt w/ MAP programmer -93 OCT tune and Stock tune -APR Stage I + II Carbino Intake system -H&R Sport Springs -AWE Tuning Touring Exhaust
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I'd definitely do sway bars first, but recommend both upgrades.
    Sway bars give a significant performance benefit by reducing body roll, while the Alu Kreuz is more for feel.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Established Member Two Rings Swat413's Avatar
    Nov 30 2015
    2005 Audi A4 Ultrasport
    Boston, MA
    Ak vs F/R Sways
    I just installed the 034 rear sway with aftermarket end links and I can say it made a drastic improvement in handling. There is significantly less body roll, and the car handles much better / feels more responsive. As for added noise, I have not noticed anything yet, granted I have only driven about 300 miles since.
    Current: 2018 RS3 // Ara
    Current: 2005 A4 USP // Brilliant Red
    Aug 12 2013
    Lexington KY
    That's what I was going to ask: Do you do just the 034 rear sway or both front and rear?
    Nov 28 2015
    Montreal, QC
    do you need an alignement done after sway ?
    Mar 21 2015
    Quote Originally Posted by waxxonMTL View Post
    Nope
    Mar 21 2015
    Quote Originally Posted by A4SlineWA View Post
    I went with Eurocode, quite a few people use them and haven't had any issues.
