Results 1 to 15 of 15
    Mar 05 2016
    IN
    B8.5 s5 6mt shifts
    S5 new owner and new to forums.
    So in March and for my birthday I purchased a new to me and first Audi. With that I'm kind of in disgust with the shifting of this car. One would figure when buying a luxury auto the shifting would at least be buttery smooth. While I can handle the tall and long throws but the notchy entry and exit of each throw has me wondering who was asleep or was rushed when designing either the rods or forks/syncros on this transmission. It's sad when my old Chevy s15 had smother shifting. Maybe I was spoiled driving my buddies sti. Is there any option to help with this? Not sure going a short shifter route will help. I'm thinking the issue is either the trans design it self or the linkage. Anyone have any thoughts?
    2013 S5 estoril blue
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    Seems like something wrong, Including mine, I have been drove over 10 b8.5 6MT and all are butter smooth! It is 100x better than any bmw and as good as most of the honda! So check out others and see.
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    And I'll say this, a short shift kit like JHM makes an already buttery smooth shift AWESOME!!!!! It does lose some of its butter, but you get positive feedback in return. Such a low cost for such a great upgrade you will appreciate every time you drive.
    Established Member Two Rings TTALMS's Avatar
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    And I would recommend pairing your short shifter with a JHM solid linkage and cross rod upgrade. Really enhances the feedback of every shift.
    JHM linkage w/ USP SS line : test pipes : pulley : intake spacers : tune : 2-pc rotors Ecode shifter : sways : end links : AK : Sport UCAs w/H&R coils & CR-15 AWE Non-res downpipes w/ GMG exhaust : intake tube w/ APR CF intake 034 mounts & inserts Style VFF103s : DEVAL : BFI knob/boot : custom s-wheel : CF inlays
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by pr1malr8ge View Post
    search the S4 forum for clutch valve.. it will shed some more light
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings Hippiekiller's Avatar
    Nov 15 2014
    Las Vegas, NV
    Quote Originally Posted by TTALMS View Post
    How much of a pain was that to install? Been thinking about doing it.
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    The stock manual is pretty crappy. I have the EuroCode short shifter kit, stainless steel clutch line with delay valve delete, and a bunch of parts to stiffen up the drivetrain and frame, and I'm only now just getting happy with it. You can make it a lot better but it took a bit for me to realize it will never be like my old Honda.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Established Member Two Rings jpatterson's Avatar
    Mar 16 2009
    Trussville, AL
    After 3000 miles in mine, it is better shifting than my Cayman S was. Mainly the clutch action is better. Similar to my Mk1 TT in that regard. No complaints.
    J. Patterson
    Alabama
    2015 S5 Prestige 6 spd manual
    2015 Q7 TDI Premium Plus (with the emissions fix)
    2001 TT 225 Quattro Coupe (some mods and track time :-) )
    2001 TT 225 Quattro Roadster ( pure stock)
    Veteran Member Three Rings SixShifter's Avatar
    May 29 2012
    York, Pa
    You are not alone in your observations, although in the minority. Before buying my first ever automatic (owned nothing but sticks for over 40 years), I test drove 6 different cars from as many dealers and each/every one exhibited the exact same properties you've described - especially the notchy entry/exit into/out of each gear. Glad to hear I am not alone ... but again in the minority. Even my wrong hand drive Quattro in my avatar shifter better than the B8.5's I tested.
    Mar 05 2016
    IN
    Quote Originally Posted by doug97gxe View Post
    While I appreciate your reply, I can tell you this has nothing to do with clutch [dis]engagement. The issue is the actual feel of the shift knob as it selects or deselects a gear. I.e. the first few and last few millimeters of travel. The actual movement in between is fine.
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    I thought the shifter feel was a little spongy when stock. I added a Euro Code short shifter and wow,what an improvement. It now feels better than any car I have driven, it has a very mechanical, yet buttery smooth feel, almost like a notched shifter. Highly recommend.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Mar 05 2016
    IN
    Well, I have not had the pleasure to be able to mainly own a MT. How ever, every car that I have owned has been a Manual. But alas I have not owned a car since the early 2000s. I used to Race Motocross [i'm a professional practice racer now lol] and that has negated any reason to own a car until now. At any rate I think I can compare the shifting of this S5 to that of my dirt bikes. It feels more like a sequential gearbox with Dogs then it does a Synchronized transmission. I'm wondering as someone has pointed out and I made mention in my first post that the control rod might be to blame. Could just be "play" and since the first and last bit of travel would transmit that play. How ever if it is not that and is the syncro system of the trans then that control rod would only exacerbate the feeling.
    Nov 10 2014
    Apex, NC
    Oh sorry too quick on the draw on that one .. Personally mine feels pretty good compared to prior cars .. The clutch delay was the annoying piece
    Present:
    Dec 26 2008
    STL
    Shifter on this car is almost fragile, so I sympathize. Every time I change into a gear it feels like something is loose or will come off.
    I think I will be ordering a JHM shifter along with the stainless steel clutch line, to remove the Delay valve. There has to be a way to make it feel like you are changing gears and not like you are throwing it in there somewhere.
    Jan 27 2010
    Cayenne%20X5
    Long Island, Queens, LA
    shifter feels great when the car's new. i've found that on both my s5s, as the cars accumulate miles the shifter feel starts to crap out.
    ig: gs.autogram
