2004 S4 - MT - 100k miles
always ran great. the other day it started and ran really rough and stalled. it wouldn't start, just turned over. I lifted the back seat and pounded on the fuel pumps with my fist, turned the key and it started and ran great. (pounding may have been coincidental) No vcds codes.
today it wont start. just turns over. I unscrewed the rubber fuel line from the fuel rail and no fuel came out. turned the key to the ON position and no fuel came out. held the key in the START position and no fuel came out. Fuel filter has approx. 3k miles on it.
so it's def fuel pump. my question is which one is it? There is a fuel pump on each side of the car under the back seat. To my knowledge the fuel pump on the passenger side is the MAIN PUMP and the one on the drivers side is the TRANSFER PUMP. but I've also read somewhere that suggested the transfer pump kicks in during starting as well. So I'm not sure which one I should replace, and based on the vehicle having absolutely no fuel pressure during cranking which pump that indicates is bad.
any help is appreciated. thanks!
**also if anyone can comment on the quality of the fuel pumps on ecstuning i'd appreciate it, as the fuel gauge always has been accurate so i'm likely just replacing the pump.
