Results 1 to 2 of 2
    Junior Member Two Rings
    Jul 01 2014
    Upstate, NY
    Intermittent Starting issues 99 Avant 3.0
    Experiencing some intermittent problems when starting my 99 A6 Avant 2.8. Sometimes it starts fine, warm or cold, other times it turns over quite a bit before it will fire up. Also, there are the times it starts, and stumbles for 5-10 seconds before smoothing out, not to mention 60% of the time it starts as if it was brand new. Can't determine a pattern, as it happens when the car has sat, after I've driven 5 miles, 100 miles, turned of and started right back up, hot, warm or cold etc etc... Want to start troubleshooting a bit because when it does happen, I think this is it, she's not going to start.....
    Jun 10 2013
    United States
    Hook up a scanner and check coolant temp sensor. When enginenisndead cold it should be the same as the idle air temp.
