Results 1 to 34 of 34
    Apr 11 2012
    Post how much boost is your tuned s3 running?
    looking to get a feel for how much boost s3s are seeing on stage1 to stage3 tunes at WOT.
    S3
    PSI BOOST SOURCE TUNE LOCATION POST(s)
    17.6-21 AUDI OEM WORLD-WIDE
    17.5-18 analog OEM San Jose, CA #2
    26-27 analog Eurodyne Stage 1.5 (91oct) San Jose, CA #7
    23-31 (spikes) analog JB1 (91oct) San Jose, CA #4
    23.7 analog APR Stage 1 (93oct) Australia #6
    21.6 analog UniTronic Stage 1+ (93oct) Australia #6
    22.7-23.5 APR Stage 1 Charlotte, NC #18
    Golf R
    Hold 24-25, Peek 26 analog GIAC Stage2+ (91oct) Phoenix, AZ #26
    A3
    30.2 (max) analog APR Stage 2 is38 (91oct) Los Angeles, CA #19 #21
    BOOST SOURCE: analog tap, vag-com logging, OBD-II, etc...
    TUNE: Stage, Company, High Torque, Low Torque, etc...
    Mar 13 2016
    San Jose, CA
    I'll leave the formatting to you. I have the Eurodyne 91 octane stage 1.5. I make about 20-21 at full boost measured via an analog boost sensor at the manifold. Stock was a max of 17.5-18.
    Supposedly, this should put me around 370 crank hp or around 310-320 whp based on dynos from Eurodyne.
    Apr 11 2012
    ^ awesome, thanks man! table updated.
    Mar 13 2016
    San Jose, CA
    Oh, I should also contribute my JB1 numbers. I got some solid, consistent power, but it was fairly spiky on the default setting (designed for 91 octane). Boost ranged between 23 and 31. In comparison to an ecu flash, it's pretty scary. Those numbers were probably somewhere around 40whp/40wtq.
    Account Terminated Four Rings
    Sep 13 2014
    New York
    How is the jb1 vs neuspeed?
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    The highest my APR S1 used to run was 23.7, while the UniTronic S1+ runs 21.6. Both via analog.
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Apr 11 2012
    Quote Originally Posted by roadrunner_oz View Post
    Thanks! 98 RON?
    Mar 30 2015
    Australia
    Quote Originally Posted by will13k7 View Post
    Thanks! 98 RON?
    Yes, 98RON
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    Noob question here, but what is the best way/tool to do some data logging?
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Established Member Two Rings ECP's Avatar
    Oct 13 2014
    Curious what the stg 3+ puts out. Hopefully I can log end of the week and report back
    Sep 13 2015
    Hell City, Az.
    how can one log using VCDS?
    I would like to know what my stage2 ED is boosting.
    Apr 11 2012
    Check out the first search result:
    VCDS Logging, How to.
    Mar 13 2016
    San Jose, CA
    Update: Will, with the new Eurodyne Stage 1.5 flash, I'm running at about 26-27psi, Stage 1.5, 91 octane.
    Apr 11 2012
    Quote Originally Posted by tateltot View Post
    nice! Updated.
    Sep 14 2006
    Thanks for posting guys.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Sep 13 2015
    Hell City, Az.
    If I want to log boost, using VCDS, can anyone write instructions? does it require a conversion?
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by selp View Post
    Or just get yourself a boost gauge, if you only care about average/peak boost. :)
    Established Member Two Rings m3th0d79's Avatar
    Feb 03 2013
    AllRoad
    CLT North Carolina
    22.7-23.5 APR stage 1 - CLT NC
    Active Member Two Rings Bradley77's Avatar
    Jan 26 2016
    TMTL
    Los Angeles, CA
    My a3 with the apr tune on the is38 turbo is 30.2 max as of yesterday.
    Apr 11 2012
    Quote Originally Posted by m3th0d79 View Post
    Quote Originally Posted by Bradley77 View Post
    Thanks guys I updated the tables, let me know if you want to fill in the blanks.
    Jan 26 2016
    TMTL
    Los Angeles, CA
    Stage 2, p3 gauge analog tapped into manifold using nuspeed adapter, 91 oct, pretty close to sea level. I think this is what you meant by filling in the blanks. I was always curious what other were boosting at. Good thread, thanks!
    Established Member Two Rings atenzany62's Avatar
    Jan 30 2016
    nyc
    anyone else with jb1 have boost spike up that high?
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by atenzany62 View Post
    I haven't read anything about really aggressive spikes elsewhere (unless people aren't measuring them), but I wasn't particularly happy. Scared me a little.
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    From George @ BMS:
    At times the with the DSG shifts it is normal to see a captured max boost of 29 on the gearshift, this is what is captured as a max.
    To be certain you can load the car low down in fourth and keep a eye at the boost or get someone to do. Otherwise do a JB1 log and forward it to me [email protected] and I can assess.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Dec 12 2007
    2015 Audi Q5
    Redondo Beach, CA
    Any GIAC boost numbers?
    Sep 11 2014
    Phoenix
    Quote Originally Posted by rj1031 View Post
    I have an R but will share anyway. I am GIAC stage 2 or 2+ (not sure what the call it these days with the better intercooler, TBE, and intake) and peak at 26psi and hold between 24-25.
    Via NewSouth analog boost gauge with intake manifold tap so should be very accurate.
    Current DD - 2015 Golf R #333
    Prior - 1990 Volvo 740, 1996 Volvo 850, 2004 Volvo S40, 2004 Volvo V70R, 2007 Volkswagen GLI, 2010 A6 Avant 3.0T, 2014 Subaru Forester XT
    Apr 11 2012
    Quote Originally Posted by brekdown29 View Post
    91 oct?
    Sep 11 2014
    Phoenix
    91 oct?
    Yes unfortunately.
    Oct 13 2014
    Quote Originally Posted by ECP View Post
    31lbs on stage 3+
    Mar 13 2016
    San Jose, CA
    Will, you may want to add a new column to the table for Brand/Tune Shop, so you can separate the level of tune from the company. Just a thought. :) I wonder if there's a convenient way to embed a Google Sheet?
    Apr 11 2012
    I'm too lazy for that. Volunteering to take over?
    Mar 13 2016
    San Jose, CA
    Maybe. ;) Let me think about it. A shared sheet somewhere would be ideal
    May 25 2016
    Wow those Eurodyne 1.5 boost numbers are pretty high...
    Anyone have any figures from the Neuspeed power module?
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by jpy1980 View Post
    Pulls like a train. ;)
