Eurocode Tuning is proud to offer the ultimate sway bar upgrade for the Volkswagen MK7 MQB Golf, GTI and Golf R and Audi 8V FWD A3 and AWD S3 & RS3 Quattro.
The pictures below link to the specific item in our secure, online store where you can find out more information on the product, or purchase.
Eurocode ÜSS Front & Rear Adjustable Stabilizer Bar Set - MQB - AWD
MSRP $399.98 Sales Pricing $339.98
Eurocode ÜSS Front & Rear Adjustable Stabilizer Bar Set - MQB - FWD
Building upon the phenomenal success we have enjoyed with our B8, C7 & 8R Audi ÜSS program, our goal was to also provide the finest setup for the MQB chassis.
To achieve equal results, our team has purchased a MK7 GTI, Golf R, A3 and S3 for in-house development. We have found that it is important to own the vehicles in order to perform long term R&D testing, which allows us to maximize performance benefits.
As most of you have experienced, the MQB chassis is quite different than anything VAG has previously released. The MQB handling is pretty darn good right out of the gate, therefore, quite a bit of design went into each and every component in both computer modeling as well as rapid prototyping.
Because we own the cars, drive the cars and are true enthusiasts, we never release a product until we feel it is the best!
Customer feedback is very important to us. We were thrilled one day when a customer stated that after installing our MQB strut tower and chassis brace, it was like “adding a sport mode 2 button” to the MQB.
Objective feedback is great, however, we are one of those old school number types, so we always test our products against the competition. To achieve this, we compared each of our sway bar prototypes against three other major sway bar “mass production” companies.
Track times, ride quality, chassis predictability and tire degradation were considered. Ultimately we chose to release what we feel is the finest stabilizer bar set available.
Each year we enter automotive magazine shootouts. We do this to benchmark the performance of our products against the rest of the industry. In the 2015 European Car Golf Tuner GP, which was published January 2016, we entered our development GTI and Golf R, outfitted with our MQB Uberlings Stabilizer System, front upper strut brace, rear chassis brace, transmission tunnel brace and transmission mount insert. The chassis improvements were instrumental in overcoming limitations of street tires on the track, securing a podium finish for both cars.
European Car magazine provided a completely stock 2015 Golf R as a “control vehicle” for the Tuner GP. The control vehicle with driver Boris Said was able to put down some very respectable lap times, with their best measure coming in at 1 minute, 19.331 seconds. With our chassis improvements our Golf R lap times improved by nearly 2 seconds to 1 minute 17.478 seconds at stock power levels. Our MK7 FWD GTI also bested the lap times of the control Golf R, coming in at 1 minute, 19.086 seconds. The best part is that our MK7 GOLF R had a completely “STOCK” ECU calibration as 2016 software had yet to be released!!
Check out the results from the 2015 European Car Golf Tuner GP HERE.
Product Features:
MK7 MQB VW FWD & FWD Audi 8V A3 (Part Number EC0202-0301R)
MSRP $399.98
- 28.6mm Diameter Front, 25.4mm Diameter Rear
- Tubular Steel Spring Construction
- 3 unique adjustment settings front and rear for a total of 9 possible combinations
- Compatible with Eurocode ÜSS Spherical Adjustable Endlinks (recommended)
MK7 MQB VW AWD Golf R & AWD Audi 8V S3/RS3 (Part Number EC0202-0307R)
MSRP $399.98
- 28.6MM Diameter Front, 25.4 Diameter Rear
- 3 unique adjustment settings front and 2 rear for a total of 6 possible combinations
Included with Each Upgrade Kit:
- Eurocode ÜSS Adjustable Front Sway Bar
- Eurocode ÜSS Adjustable Rear Sway Bar
- Polyurethane Front Sway Bar Bushings
- Polyurethane Rear Sway Bar Bushings
- Silicone Sway Bar Bushing Lubricant
- Stainless Steel Front Installation Hardware Kit
Vehicle Fitment:
- 2015- VW MK7 MQB Golf/Golf Sportwagen
- 2015- VW MK7 MQB GTI
- 2015- Audi A3 8V 1.8T FWD
- 2015- VW MK7 MQB Golf R
- 2015- Audi A3 8V AWD
- 2015- Audi S3 8V AWD
- 2015- Audi RS3 8V AWD
Specifications:
FWD (Part Number EC0202-0301R)
Front
- Rearward Setting: +18% over middle setting
- Forward Setting: -20% over middle setting
Rear
- Rearward Setting: +9% over middle setting
- Forward Setting: -10% over middle setting
AWD (Part Number EC0202-0307R)
Front
Rear
- Rearward Setting: +9% over front setting
Frequently asked Questions:
Q: Some of the aftermarket sway bars come with aluminum or steel installation brackets with grease fittings, why do you retain the OEM?
A: We modeled and conducted stress analyses on both stock and billet brackets and found no added benefit. The factory bracket is 100% capable of securing both the factory bar as well as our bar, without any change in deflection under load. The only advantage we found on some of the brackets was that the sway bar did not need to be removed to re-grease the bushings. However, we did not feel that was enough of a benefit for the added cost. We will be making a zerk style bracket in the near future for those interested in such a product.
Q: Are your adjustable front and rear end links required for installation?
A: Our sway bars will work with both the OEM endlinks as well as our ÜSS spherical adjustable front and rear endlinks. However, to use all settings on the rear sway bar the use of our spherical endlinks is required. This is due to the lack of articulation from the factory rear link.
Please give us a call at 310-294-8108 or email us at [email protected] if you have any other questions.
