Results 1 to 4 of 4
    Mar 21 2011
    magimmeMVE
    Usa
    Major codes, misfires etc..
    What's up everyone. I just got my car back from the shop. I had a power steering return line rupture that was replaced and changed my battery under the 36 month replacement Duralast warranty. The battery only lasted 23 months. As you guys may know, the S4 has been my daily driver and has 150,000 miles. So basically a week and a half after getting my car back I had to limp home with random misfires. I got home and connected the laptop I have with VCDS. Below are the codes. I hope it's as simple as spark plugs and/or coils.
    14 faults in total!
    Address 01: Engine Labels:
    Control Module Part Number:
    Component and/or Version:
    Software Coding:
    Work Shop Code:
    VCID: 55A585678587
    14 Faults Found:
    17546 - Fuel Trim: Bank 2 (Add): System too Lean
    P1138 - 001 - Upper Limit Exceeded - MIL ON
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 001 - Upper Limit Exceeded - MIL ON
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded - MIL ON
    16689 - Cylinder 5: Misfire Detected
    P0305 - 001 - Upper Limit Exceeded - Intermittent
    16891 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - MIL ON
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded - Intermittent
    16687 - Cylinder 3: Misfire Detected
    P0303 - 008 - Implausible Signal
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded - Intermittent
    16691 - Cylinder 7: Misfire Detected
    P0307 - 002 - Lower Limit Exceeded - Intermittent
    16666 - Fuel Injector #8 (N86): Short to Ground
    P0282 - 002 - Lower Limit Exceeded - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    17536 - Fuel Trim; Bank 1 (Mult): System too Lean
    P1128 - 001 - Upper Limit Exceeded - Intermittent
    17538 - Fuel Trim; Bank 2 (Mult): System too Lean
    P1130 - 001 - Upper Limit Exceeded - Intermittent
    16690 - Cylinder 6: Misfire Detected
    P0306 - 001 - Upper Limit Exceeded - MIL ON
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    you're lucky, you don't have any timing related codes !
    on the other side, check your battery voltage, with the car turned off, and while idling(make sure your alternator is charging properly) .
    what exactly "triggered" this problem ? ( can you recall the last thing you did before it all started ?)
    Mar 21 2011
    magimmeMVE
    Usa
    Quote Originally Posted by jakeoboy67 View Post
    yeah, tell me about it. Pretty much nothing I can recall other than just swapping out a battery and the power steering return line.
    I will check the voltage tomorrow and post back.
    I hope it's not too serious. I just got her back from the shop!
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Vacuum leak, my 2¢.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
