02 tip allroad, factory wheels and tires.
My left front axle has puled out from the boot on the transmission side twice before however my air ride wasnt working properly and i was on bump stops.
So when the axle pulled out before i knew for sure it was due to pinion angle being excessive. Since then i replaced my air ride compressor and manifold and im very happy to say my air ride works great! However yesterday while cruising on level 2 (no crazy pinion angle) the same left front axle pulled out from the inner boot....again. So obviously i have something else going on. I was hoping someone has had the same concern and can point me in the right direction.
Bad mounts allowing too much movement?
