Results 1 to 3 of 3
    Nov 10 2006
    B7 A4
    Detroit Michigan
    JHM FLYWHEEL torque 2.0t TFSI Audi A4 quattro
    Hey guys in a pinch. I dont have the correct flywheel bolt torques. The bolts that came with the kit has blue loctite on the threads. The install sheet for the web site looks like its for a V6 or an S4 and calls for red loctitie. Does anyone know what im supposed to torque the aluminum flywheel to crank bolts to?
    Mar 24 2013
    Oakdale, CT
    The instructions don't have the torque spec? Mine did. IIRC, it's 45 ft-lb. and then turn an additional 90 degrees. I'll try to verify. About the loctite though, you want to use red in addition to anything thats on the bolts already.
    Edit: https://jhmotorsports.com/instructio..._flywheels.pdf
    If you have the reusable bolts, it's 65 ft-lbs.
    -Adam
    Nov 10 2006
    B7 A4
    Detroit Michigan
    I purchased this flywheel almost two years ago and it has been to 2 machine shops and 2 households, I have no idea where the instructions are. Thanks bro.
