Results 1 to 40 of 49
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Got boost? cuz i dont.
    dont SEARCH button me please. I dont have the time or the patience to go throughb hours of searching
    Ive got like 3-4 lbs of boost and cant find where my leak is. I will try the tennis ball method but I would like you guys to post potential/ most common areas of vacuum leaks. also, would an exhaust leak causr this kind of loss of boost?
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    did it all of a sudden just quit making boost and drop to 3-4lbs?
    contact via email please.
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    limp mode
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Aug 05 2005
    east coast
    limp doesnt do 3-4 it does 5 and im sure he knows what the hell limp mode is
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    Check the L shaped hose by the top of the intake manifold.
    2016 Audi S3
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    the diff from 3-5 isnt that great, could be limp mode.
    common leaks are the DV to manifold line in front of the TB cover, the FPR line on the back of the intake mani, and any lines you may have run
    Sep 13 2004
    wow, ass...
    ive seen guages that sit 3psi off from where they should be... 1-2psi is minimal, get over yourself...
    Active Member Four Rings
    Could very well be in Limp. You really just need to get it Vag'd
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    My buddies GTI did that when he blew the turbo.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    WHAT HE SAID
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    well, first off...what is you vac reading on your boost gauge? it should be like 20-22.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    for everyone that says check all these small hoses..do you realize how much of a leak there has to be for it to leak 10+ psi of boost??(assuming hes chipped)
    it would have to be an IC hose blown off
    ive blown hoses part way off before and still get 5psi..a split L shaped hose or a torn fpr line isnt going to leak 10psi
    sounds like limp mode...espicially since we're getting into the colder months, the ecu might not have adapted yet and still be requesting a few psi too much
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    if the car drives fine other than the low boost pressure than it is likely limp. You could always pull the battery to see if you get boost pressure back at least for a short time.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Oct 17 2004
    Columbia, SC
    doesnt mean there isnt a leak. is it really that hard to listen for a leak and check 2 hoses? probably is limp mode, but id still check the hoses.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Yeah, im reading 21 for VAC.
    MITCH
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Originally posted by 1.8.se7en
    limp mode
    I thought of limp mode, but doesnt that only happen when there is a check engine light???
    MITCH
    Veteran Member Four Rings sumpsfast's Avatar
    Apr 02 2004
    '92 UrS4 - Black
    Denver/Chi-town
    Wierd question man, I almost posted and asked this tonight before I disconnected the battery and did the throttle body adaptation. I was DEFINITELY in limp mode and had no CEL!!!
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Also, i am not chipped yet. GIAC PC-16 this weekend though, WOOOOOT!
    MITCH
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    You won't like the pc-16 file....so why don't you sell it to me?
    Looks like limp mode for you man.
    The harder I practice, the luckier I get.
    - Gary Player
    no, limp mode will not through a cel
    disconnect your battery for 5 mins or so
    Sep 13 2004
    make sure you know your radio code...
    Veteran Member Four Rings RedRocket's Avatar
    Feb 12 2004
    Toronto GTA
    Umm, don't you have an AEB Quattro? If so you won't have limp mode, nor will you have that L shaped hose by the intake. Unless people were talking about the IC hose...
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    so AEB doesnt go into limp?
    Feb 12 2004
    Toronto GTA
    Yes, the throttle is by cable. AEB's don't go limp. If it were possible, I'd have been there already.
    Jul 21 2005
    '99.5 A4 APR Stage 3+
    Alabama
    So true RedRocket. If he's about to go PC-16 that means he's pre '00 and therefore NDBW. So unless I'm mistaken his car doesn't have a limp mode.
    Feb 12 2004
    Toronto GTA
    Ya, and I've seen his engine with my own two eyes
    Feb 12 2004
    Toronto GTA
    Quattro, are you comming to the cruise this Sunday? I will have my VAG USB there.
    just because its dbc doesnt mean the TB doesnt have a motor bolted to the side of it...
    the ecu can still make decisions for you
    Feb 12 2004
    Toronto GTA
    that's true. Be we dont' go limp
    the ecu can still close the throttle though and limit boost that way
    Feb 12 2004
    Toronto GTA
    I don't know about that. The throttle is manipulated through a second rod on the throttle body that is operated by vacume correct? This is for Anti-stall and Cruise control. If it were able to reverse the vacume function by pressurizing that diaphram on the bottom, it would be working against the force of your foot.
    So if he was experienceing throttle cut, he would feel something overpowering the accelerator pedal. I don't think this is likely what is happening. Know what I mean?
    Of course you can understand why this is not the case in DBW cars.
    yea..i see what youre saying
    it just seems kind of strange that he has perfect vacuum, cant find a blown IC hose, and is losing boost..
    Feb 12 2004
    Toronto GTA
    Well the vac is from throttle to cyclinders right...
    I think he should to a TBA. I had a problem like that and it turned out the ECU was unable to adjust the TB. I ended up getting a used ECu from a junk yard and it fixed it. Weird.
    He can't even read bost requests i don't think because it's an AEB. At least in 97(my car) the AEBs don't have that feature.
    I would suspect a leak with around the DV since he just put in a forge. It won't be the vac line on the top of the dv, unless it's fitted in a way that it allows vacume but not boost. This is going with most likely.
    Less likely, assuming something happened to go wrong at the same time he made a change to the car, I would either suspect throttle issues, or N75 maybe. What would you guess komp?
    Interesting enough, my car would only boost at like 10 Psi cause the car was only reading 73% at the throttle on WOT with the bad ECU. When it should read like 85%.
    im betting on his boost leak had something to do w/ the dv he installed which progressed into it deciding it was going to blow itself off the hose
    he never did say whether it just all of a sudden lost boost or whether it got worse over time..
    Feb 12 2004
    Toronto GTA
    ^^^ya me too. If he doesn't have it solved by Sunday, I will stick my VAG in and have a look. I'm getting better with the VAG, do you have any suggestions or know and specific blocks I can measure? Keep in mind I'm not sure if he has requested boost.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    If the install goes well this saturday, I will be out for sure. But I have a feeling its goona drag into sunday.
    MITCH
    Feb 12 2004
    Toronto GTA
    Are you sure the K04 is welded up nicely? no leaks? And be sure to have all the new gaskets and non reusable nuts to be on the safe side. Are you installing yourself?
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Ive actually had boost problems for quite a while. somedays theres a little more boost than others. ive also replaced a bunch of vac lines a couple weeks ago but nothing has gotten better.
    MITCH
    Feb 12 2004
    Toronto GTA
    Well did it gradually get worse or was in sudden?
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    gradually, I didnt even notice my car had no balls because it wasnt right away.
    MITCH
