Results 1 to 15 of 15
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Satellite Radio Help
    My car was originally equipped with an RNS-E and Park Distance control. I recently bought a Sirius satellite radio receiver Part# 8E0 035 593D and my car is not recognizing the device. Do I need to code in the receiver via VAG-COM/VCDS? If so how do I do it. If not did I purchase a bunk receiver? Thank in advance for the help.
    "Brake last, finish first."
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Make sure the part number is compatible with your car then call Sirius to transfer to the new box
    Sent from my VS990 using Tapatalk
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by [a]bek. View Post
    I believe the part number to be correct as I did research before I bought it, but am beginning to believe it may not be right as the car cant see it. I can not even access the channels so I may activate the box.
    Oct 03 2007
    New York
    Sorry, but the "D" version won't work. You need to source an "E" : 8E0 035 593 E
    http://www.ebay.com/itm/AUDI-VW-VOLK...1WaLMs&vxp=mtr
    AKA: Eightx3
    Mar 14 2013
    Call and Audi dealer and give them your vin, they'll tell you. That's what I did when I was looking for mine
    Mar 14 2013
    I have one 1st home, I will check for you tomorrow what the part # is. If it's the one you need I can sell it to you cheap
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by Matt C View Post
    I tried the "E" version today also and still had the same issue with the RNSE not recognizing the receiver. This makes me think its something that needs to be VCDS/VAG-COMd in. Anyone??
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    You might check and see if that purple plug has been switched over. By the passenger seat, on the right side, under the glove box.
    "You have to switch the CAN BUS connection near the passenger foot well - Don't be intimidated - this is a peace of cake. Don't be afraid to pull straight up on the plastic molding. Removing the CAN BUS connector is tricky - I fought with the dang thing for over 20 minutes before I was able to sneak it out. It has some kind of clip on it to release it and I couldn't figure it out for a while, then it just popped out on me. So, if anyone has a trick on this (besides playing around with it for 20 minutes) feel free to post. Really - it's easy. Once this connection is switched - see photos and directions in PDF, you are done and you just have to call Sirius or XM to set up." - Link
    In regards to the actual module, I found this as well:
    "8E0 035 593/8E0 057 593 Sirius without RNS-E and without tire pressure monitoring system
    8E0 035 593 A/8E0 057 593 A XM without RNS-E and without tire pressure monitoring system
    8E0 035 593 D/8E0 057 593 D Sirius for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well
    8E0 035 593 E/8E0 057 593 E XM for RNS-E and/or with tire pressure monitoring system, works with Concert/Symphony as well"
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Mar 11 2008
    B7RS4 & e46Ms
    My '07 came with: 8E0 035 593 F
    NYC, are you adding a sirius module where you didn't have one before, is that correct? Do you have a cd changer or ipod in the glovebox?
    FRRG AZ Ring
    Oct 14 2009
    AZ/NY
    You are correct Sir, on both accounts. (My RS is also a 2007)
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    wait you have a factory Ipod system DO tell
    my 07 has sirius and the cd changer too dont know where an ipod would plug in
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by Aok303 View Post
    I bought the car with it installed, You can find the Audi iPod hookup kits online however, it's a bit antiquated now a days. I'm forced to use a 30pin to lightning adapter on mine. It's routed through the glove box to the back of the RNSE. However, if I were you I'd just spring for the Denison adapter and be done with it, it has many more features and IMHO a much better way to go.
    Jul 28 2008
    Everywhere
    You do have to code it with vagcom, your coding should be similar to 0329666
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by NYC_Legacy View Post
    Okay, makes sense now. As junaid mentioned below, double-check your coding first. That may be the easy button...
    So many of the aftermarket iPod adapters actually use the sat radio circuit. In many cases, it's a 'one or the other' scenario. I honestly don't recall the specifics as it's been years since I was really familiar with the system. Check the telematics section or the RNS-E section of audiforum.us, that has all the content from the old navplus.us forum. Hopefully that gets you moving in the right direction.
    FRRG AZ Ring
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Make sure your rnse isnt in lambo mode - it wont recognize the satelite reciever
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
