Results 1 to 7 of 7
Thread: BPY Crankshaft
    Dec 19 2011
    Colorado Springs
    BPY Crankshaft
    I'm sure its a long shot...but if anyone some how happens to have a motor they're tearing apart and want to sell me their Crank.. Please shoot me a pm!
    05.5-08.5 B7 A4 2.0L should be BPY.
    - Dave
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Mar 24 2013
    Oakdale, CT
    B7s had BPG engines from 05.5-06 and BWT engines from 07-08. BPY engines were in the transverse cars (A3, GTI). That said, the BPY internals can be swapped interchangeably between all three engine codes. Were you looking for a manual/cvt or a tiptronic crank?
    -Adam
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    How about the ALH crank? Requires a bit more work, and thicker head gasket? But likely the cheapest solution (found 4 in Canada for $150cdn that's prolly 25-50Usd with exchange now). Possible option of OP is going to be doing some work?
    Dec 19 2011
    Colorado Springs
    Good info!! Thank you sir!!
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    I have a BPY crank that is for Tiptronic (not manual/cvt). Let me know if interested.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Dec 19 2011
    Colorado Springs
    I may have sourced one locally.. but let me know cause I'm gonna need another one.
    Feb 10 2012
    parts
    Napanee, ON
    Ebay has one right now listed for $169.99. Item # 141875807358
    Just going by listing I'm unsure if it's the right one. Worth sending a message at that price.
