Results 1 to 4 of 4
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    Stock exhaust ??
    ??? Does the stock exhaust system come apart our is it all just one lengthy piece? Going with a new system soon and was wondering if I should keep the stock setup and will it fit in the S4 for the ride home.
    What does everyone else do with there stock setup?
    Sent Blu's iPhone...
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
    Mar 21 2015
    No it won't fit unless you cut it. Bring a truck with a strap or two. Mine is sitting in my dads shed.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    No way it will fit in your car, I took a pick up truck to get mine back from the shop
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    just swapped my stasis on my new s4 and no bloody way the stock one will fit in the car. Id recommend a truck as well
