2001 A4 1.8T AWM
I Recently replaced the cylinder head due to timing belt snap. Ive checked the timing 5X and marks are all in line & the fuel pump is working. I've replaced: Cam sensor 3X, replaced fuel filter, fuel rail, maf sensor and Vac lines are all good.
I know the coil connector on my #1 is crusty and needs replaced.
What I don't know: I was told the timing chain was already aligned and I did NOT need to do anything with it. Could it be off??
Would the bad coil connection on #1 cause a 2-3 crank start?
I did take her into a German auto shop a couple weeks ago to have them do a one over on my work and hopefully sort out the 2-3 crank start issue. Unfortunately I lost confidence in their abilities when they popped the hood and shut it with a tool left inside, causing the hood release cable to come off. To add insult to injury they couldn't pop it open from underneath so I brought her home and popped the hood myself.
I've done a lot of work to this car myself thanks to this site but I'm far from a mechanic.
Anyone have any suggestions?
