Page 1 of 4 123 ... LastLast
Results 1 to 40 of 145
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Dual Pulley (DA + 662 ft) results --> [email protected]
    Hi all,
    I managed to get to the track at Bradenton Motorsports for their test-n-tune this morning around 10am. Weather conditions were nice, and I started at approx 10:15 am and ran only for a 1 1/2hr or so. Track prep was so-so even though there was an event, I managed to spin my first run ([email protected]), so I decided against using LC.
    Weather conditions: 71F / humidity 28% / pressure 30.16Hg when I started. Track elevation approx. 50 ft. Effective density altitude is 662 feet, and went up to 797 feet by the time I left as temps rose.
    Mods are:
    Mods:
    GIAC Stage II ECU (version 2, RACE file)
    GIAC TCU file
    AWE-tuning pulley
    JHM Overdrive crank pulley
    Chipwerke Pro (4-1 setting)
    aFe Pro 5r air filter
    034Motorsports TBB
    OEM Airbox box w/ 2.5" hole mod
    X-pipe mod
    Wheels/tires: Stock OEM 19" rotor wheels (S5), 255/35/19 PSS set to 39f/38r.
    Fuel: 1/2 tank of my usual 93/E85 mix (approx. 37.7% total ethanol content).
    Weight reduction = none (I forgot to remove my spare tire/jack prior to leaving and I didn't want it sitting at the track unattended)
    I set my Chipwerke Pro to 4-1 (dialed it down from 5-1), which helped my shift issues on the 2-3, but the 3-4 still is not 100% smooth, almost like the transmission pauses before it decides to upshift on each of my runs (it was a symptom prior to installing the CW, so I'm not placing blame on that). My runs in the below pictures are slowest to quickest, here are the results from my quickest run:
    R/T .266
    60' 1.610
    330' 4.659
    1/8 7.210
    MPH 97.19
    1000' 9.396
    1/4 11.240
    MPH 122.44
    The launch for the two quickest times was using a two-foot technique. It's hard to describe, but when you are at the christmas tree, you hit the brake (DSC fully off, dynamic mode, D/S mode on the tranny), and when the lights signal you to go, you stab the gas WOT as you quickly (but not immediately) let off the brake. The results were revs jumping up to 4,500 rpm as the car accelerates, which is different than using Launch Control where the car stands still at 4,500 rpm and then accelerates when you release the brake.
    Some notes:
    -The IAT's on my slowest run in the picture (my last last run, and when I decided to use Launch Control again as I noticed more and more people with drag radials were going and laying down rubber for us street tire people) started at 52C because of long lines and improper cooling prior to that run, and reached 84C (183F!) by the end of my run, which is why the trap and MPH is low compared to my other two runs despite a 60ft time of 1.584 (<---I take back what I said about PSS not having good accelerative grip!). In theory, that run may have landed me 11.0-11.1x@123-124 mph! Darn! I did not log the two quicker runs, however my VDCS was on and the IAT's ranged from 30C - 70C by the end.
    -The 3-4 upshift pause is costing me some time (I've seen my times affected by .05 - .1 seconds on prior drag strip visits)
    As such, I'm happy with the results, and I can't wait until the fall when I have at least some form of S/C cooling to keep IAT's at bay and DA's closer to 300 feet, and maybe run less fuel as well as removing the spare/jack.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 11 2012
    wow, ur killing it. is that a new dual pulley record?
    Nov 20 2014
    New York
    That's awesome congrats! Stock supercharger record holder on the 3.0T platform!
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Nice work Loe,a truly amazing run.
    Awesome ET & MPH
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Super impressive! I love that you're running these times without race gas, too!
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by LINDW4LL View Post
    I love that too and that he's on stock wheels, rotors and cooling system. Almost knocking on the door of that stripped out stage 3 eurocode car... Congrats Loe!
    Nov 20 2014
    New York
    Is the S5 weight the same as the s4 around 4000 lbs? Or is it a little lighter, you know because less doors haha
    Jul 21 2004
    South Florida
    Awesome loe! It's great that you still have some left in it too. Next year when we get that one 50 degree day you'll kill it. Great job
    Mike
    2018 Audi S5
    Gone-
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by mrmomo313 View Post
    Yes! I hope tuners take notice and start to write specific dual pulley files.
    -Hayden
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    Absolutely amazing Loe. Keep at it, getting me excited and interested in the platform again :-)
    2012 S4 - DSG B8 - [email protected]
    Dec 14 2009
    Houston, TX
    Awesome work I knew this potential was there!
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Congrats, good numbers!
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Mar 28 2014
    Awesome times! Well done.
    2014 S5 APR Ultracharged
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    Awesome time, but I don't understand how you are running a tune AND have chipwerke?
    Aug 09 2015
    Sarasota, FL
    Thanks all! Lets see who gets to the 10's on a stock S/C'd car this year. I have a feeling that my time will be beaten this spring!
    I wish more tuners would write a specific file for this fuel combination, or at least have some auto-tune based on ethanol content via a sensor (factory E85 vehicles do this already).
    Thanks man! I'm surprised as well that I'm able to trap that speed with the stock cooling and IAT's approaching 183F near the end of the run. You'd also be surprised that my knock correction value hovered at 0 for the majority of that run. Ethanol content + DI at its best!
    Quote Originally Posted by bhvrdr View Post
    Mike
    Dec-March will be the season, it'll be a long summer/fall that's for sure! Hope tuners are able to help you out with the A6!
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    Quote Originally Posted by LittleDozer View Post
    Would like to hear the reasoning as well.
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by psiaddict85 View Post
    It's to only control boost bypass to allow a standard stage 2 file to run a dual-pulley set-up in order to see an increase in boost pressure (otherwise it would be bled off and the boost pressure would be equivalent to a stage II car). Specific dual-pulley files are available, but only with EPL at the moment. I didn't want to switch tuning company's (again), so I improvised and logged to make sure the car is happy for the time being until GIAC releases a file.
    Jan 21 2014
    Quote Originally Posted by Loe View Post
    It's to only control boost bypass to allow a standard stage 2 file to run a dual-pulley set-up in order to see an increase in boost pressure. Specific dual-pulley files are available, but only with EPL at the moment. I didn't want to switch tuning company's (again), so I improvised and logged to make sure the car is happy.
    That's why I'm EPL
    Nov 09 2011
    Michigan
    That's why I'm EPL
    Well, get your ass to a track.
    Jan 21 2014
    Quote Originally Posted by Jones2012s4 View Post
    Haha I will. WOT it's limping into 4th gear so putting in a new HPFP next week. While at it doing the upgrade to run full E85.
    Aug 09 2015
    Sarasota, FL
    Very cool, can't wait to see the results! Good luck to you!
    Nov 09 2011
    Michigan
    These are the times I really want to see:
    Full E85
    Dual Pulley
    HPFP
    Can't wait, hope you get everything sorted!
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Awesome times... to the poster above, I believe the S5 is the same curb weight however I've seen some that range 100-200lb heavier.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    So close to 10s!
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Damn! Nice run
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    Wow in an S5 too.. An S4 might have clipped off another .1 from weight
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Awesome runs Loe!!
    So if you decided against LC what was your technique? Those are really good 60' times.
    2016 S6
    Nov 09 2011
    Michigan
    Quote Originally Posted by AudBoost View Post
    Awesome runs Loe!!
    Read his first post......
    Aug 09 2015
    Sarasota, FL
    Awesome runs Loe!!
    hard to describe, but its a two-foot technique that allows the car to accelerate on the up-swing of the clutch engagement at 4,500rpm. It's like a less violent version of using straight LC, but much better than the stomp-n-go method, and it resulted in those excellent 60ft times; but on my final run using LC I did get my best 60ft time of 1.584.
    On a side note, when I use the two-foot method, it doesn't go towards my LC count according to my VCDS logs
    Nov 09 2011
    Michigan
    hard to describe, but its a two-foot technique that allows the car to accelerate on the up-swing of the clutch engagement at 4,500rpm. It's like a less violent version of using straight LC, but much better than the stomp-n-go method, and it resulted in those excellent 60ft times; but on my final run using LC I did get my best 60ft time of 1.564.
    Technique that Primetime pioneered. Has also netted me a 1.5x 60'! works very good when you get it right.
    Aug 09 2015
    Sarasota, FL
    Yes sir! The primetime method!
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Nice work Loe.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Very good job!!! Gonna have to to try the 2 foot method. Great launch and great time. . 10's are imminent...
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by derek.kritz View Post
    We just need more S4/S5 owners on board with the dual-pulley set-ups to make it happen! Jump on board
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice run brotha! Just keep at it and soon you'll click off a 11.1x 😎
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Oh I am!! Just waiting for mine!!! Both full e85 and 91 octane are ready to go for me. Just need the pulley.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Awesome work! I'm hoping we see 10s this year! Props to all the folks like OP taking the time, money, and effort trying to push the envelope for the benefit of all!
    2021 Audi S4, P34 Intake
    Jan 28 2015
    BMW 435i Grand Coupe 2015
    Melbourne, Australia
    That's interesting... the pause that you describe from 2nd to 3rd happens on my car as well and I have the Racechip piggyback... I have the SENT or new digital sensors and i have set my racechip module under all levels from 5 to 9 and i still experience that pause...Without the racechip module that hiccup disappears... I have spoken to racechip and they're haven't done anything about it nor provided any suggestions.. they simply just stick to their "don't know, we have never heard of that happening" response.... mmm
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by ChobeG View Post
    I don't have any experience with the Racechip, I my understanding is that it manipulates more than the manifold pressure sensor correct? Have you tried resetting the ECU after installing it?
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    With OE wheels plus trunk full of tools. Very promising you'll be in the 10s soon, keep it up! Exciting times ahead for dual pulley/E85.
