Results 1 to 8 of 8
    Apr 09 2016
    Las Vegas NV
    To buy or not to buy. 2005 A6 109k
    Negotiating with dealer right now for 2005 A6, 3.2. $9000 out the door. Has 109k on the odometer. Maintenance record from 2 previous owners is excellent with all maintenance being completed at the Audi dealer since 2005. Has normal wear and tear for an 11 year old car. Potential repair costs have me spooked. I have read about timing chain stretching and I'm curious if this is something I should worry about on a vehicle that has been well maintained. I drive about 15k miles a year and I need it to be extremely reliable for the next 2 years.
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    I don't think you have to worry with good records, I have a 2007 and just hit 170k and drive almost 24k a year. I've had to replace some seals that were leaking and have changed the oil every 5k. The chains don't stretch had much as the guides for them loose tension which causes the problems but if you only need 2 years of reliability you'll be well below where I'm at now mileage wise. I'm hoping with good maintenance to get 200 - 250k out of the engine.
    Sent from my VS985 4G using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Run away.
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    Quote Originally Posted by Kevin1 View Post
    Run away.
    agreed!
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Active Member Two Rings sushimi's Avatar
    Oct 20 2007
    08 A6 Avant
    The Beach, NJ
    I think haggle down the price a bit, I recently bought a 08 avant w a bit less miles for ten
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    I too believe the engines on these cars will last, so if it had regular and correct maintenance, 109k ain't nothing.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Mar 03 2016
    St. Louis, MO
    I just bought a 08' A6 with 58k for 14,1. Coming from previously owning a 545i, I knew what to expect and made sure to get a warranty/gap insurance. I had to get the coolant system redone and a few gaskets changed in the BMW. The insurance covered everything. I've never had a problem submitting a claim. You always hear horror stories about that but honestly it's because people don't read the fine print and actually know what they are getting. Just my two cents. If you want the extra peice of mind, get GAP.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by brad11140 View Post
    So lets break down the issues here.... You have some saying "run away" and others saying go for it. @kevin1 owned an 4.2 A6 from day one and ran the car for many years and had an extensive list of issues he encountered along the way; some of which were covered under warranty and others not covered because they appeared after the warranty expired. Needless to say, he had invested a significant amount of money in maintenance and repairs over the long time of ownership. @Kocky123 owned his 4.2 A6 for a short period of time and he experienced a myriad of issues from the start and sold the car quickly because he did not have a service history on the car and did not want to run the risk of major repairs/expense due to the unknown. Both have valid points of view to consider. @dutch_A6 and @c@@kiemonsta both own the 3.2 A6 and have direct experience with that motor/car with similar or more miles than what you are looking at and their points of view are valid as well.
    Myself, having owned an 05 4.2 and currently owning an 09 3.0t, can say that these cars and motors are very solid and reliable as long as they have been well maintained and serviced appropriately. The risk of buying used is, did the previous owner maintain the car and are there records? I have always advised people looking to purchase a used Audi to GET SERVICE HISTORY! If there is no service history available then walk away! If the PO can produce a detailed service history, then the odds of having any issues related to neglect diminish significantly and confidence in purchasing rises correspondingly. Now, does that mean that you wont experience any issues?? NO.
    The 3.2 motor does have some well documented issues that should be taken into consideration when purchasing:
    - Carbon buildup.... The 3.2 is a direct injection motor and is susceptible to carbon build up and should be considered a maintenance item that should be done regularly to keep the car operating at its maximum potential.
    - Timing chains/guides/tensioners.... The issue here is the guides and to some extent the tensioners. Chains are not going to "stretch" to a point of causing issues. The guides are made of plastic and, as with anything else made of plastic, will degrade and become brittle and could potentially break. Tensioners could also fail due to wear and age. If any of this happens, then a catastrophic engine failure will ensue because these are not "non interfering" motors. In other words, if there is a failure in the timing system, cylinders will crash into valves and major damage will occur requiring a complete engine rebuild. Performing maintenance on the guides and tensioners is not an easy task due to the placement of the system; on the rear of the motor between the motor and transmission. The upper tensioners can be serviced without having to pull the motor, but any other components will require the motor and trans be dropped and "split"; labor intensive.
    So whats my point..... Purchasing any car (new or used) is not without risk. New cars have the safety net of a warranty that will cover most anything (except willful abuse/neglect); Used cars generally are "as-is". If you feel comfortable that the car has been serviced/maintained properly (which it sounds like it has been) and you go into the purchase understanding there could be issues in the future, and you are comfortable with that, then I say you are looking at a car that gives you the best chance of a long and happy ownership experience.
    '09 C6.5 A6
