Results 1 to 7 of 7
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    How do I identify which ring and pinion Is in a diff?
    I've bought a used diff as a possible replacement for the stock one in my 2001 A4 TIP. How can I find out what ring and pinion are n the replacement without taking it apart?
    Thanks
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Dec 10 2013
    Borden, Ontario, Canada
    Just replace it with the new one. Why bother taking it apart?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 22 2012
    Indianapolis, IN
    Because I don't know for sure if the replacement has the same ring & pinion ratio.
    Neil M.
    2001 A4 1.8TQ, TIP
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Well... You could try the good ol' spin method..
    "One somewhat easy yet very reliable way is to jack up the wheels, disconnect the driveshaft, rotate one wheel, and count how many revolutions the pinion yoke/flange makes."
    Based off of that you can get a ratio....
    Nov 14 2011
    NW
    There's lists out there to decipher amount of rotation into gear ratio. It'll be for 4x4 trucks and the likes for the most part.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Well, it should have a code stamped on it somewhere
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    Yep. Just read the code. Then AZ members will decode it for a small fee. ;)
