Results 1 to 7 of 7
    May 05 2014
    F80 M3
    B&O door speakers
    So ive had this small buzz on the outside of the door that has been driving me nuts. So I took the panel apart to add some sound deadening. Found out that what I thought was a 6 1/2 speaker in the door is actually an 8" speaker. No wonder why it has such good midbass. While in there, I threw on some dynamat and put it back together. The sound from the door I treated to the stock door is SO SO much better. the midbass seems more nailed down. Definitely a cool upgrade.
    Some pic of the false floor with a 12" OnCore sub and OnCore amplifier.
    Feb 18 2016
    Infiniti QX60
    SD
    sweet, lets see your setup under the floor?
    Mar 24 2016
    UK
    Is it possible to highlight where you placed the dynamat please I can't tell what is and isn't factory fit ?
    Cheers.
    Established Member Two Rings Maxim's Avatar
    May 15 2015
    HI
    Very nice write up. Not much info for the audio systems on the forum yet.
    PS. How were the door panel taken off? Thanks
    May 05 2014
    F80 M3
    Quote Originally Posted by hbracer93 View Post
    Feb 18 2016
    Infiniti QX60
    SD
    Quote Originally Posted by P2WRTMR View Post
    Awesome, Thank you. Does all that foam stuff come out? I'm assuming it does, I plan on putting my air setup in the spare tire along with my subwoofer
    May 05 2014
    F80 M3
    Yes the foam stuff comes out.
