    Aug 12 2008
    atlanta
    CEL Secondary Direct Air Pump P0411
    Shop quoted me $700 to fix this with new pump and relay.
    Both pump and relay work when connected to the battery, what's the next step? I'm just trying to pass emissions. I hooked up a new chinese pump that also works, haven't replaced relay, but tested. Can they stick, should I just replace it also?
    Thx
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Are all of the hoses connected to the SAI pump?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by imnuts View Post
    This Before you pay a shop $700 to replace parts that check out when hooked up to the battery you need to do a little diagnosing yourself. The first step is to understand how it works. Your problem could be as simple as a broken vacuum hose. Here's an outstanding resource:
    Aug 12 2008
    atlanta
    Yeah, hoses are fine. I watched that video, my problem is electrical I think. When and for how long is the pump supposed to run? I keep reading on cold start but no mention of duration. I had power at the connector but I guess I need to make sure its enough b/c mine doesnt kick on.
    No water in the pump either
    Dec 28 2006
    Western Maryland
    The SAI pump should start immediately and run for approximately 90 seconds. Concurrent to that you should have a high idle and reduced vacuum. The reduced vacuum is being caused by the 22° of intake cam advance and the retarded ignition angle. By the end of the cycle the cam advance returns to it's normal position and the ignition angle goes from 3°→5° ATDC to somewhere between 6°→9° BTDC. Vacuum also returns to normal.
