Results 1 to 18 of 18
    Senior Member Three Rings JoeyManhattan's Avatar
    Oct 04 2013
    '01 VW Passat B5, '92 MB 300E 2.6, '19 F150 Limited
    United States
    Well...She's Going Under the Knife
    It's been many months since she was irreparably damaged by acorns without paint work, but the time has come...
    Though I hated the idea of not having original paint anymore, I decided that if paint was to be done that she deserved every scratch and dent removed. While I was at it, non-rippled door lowers, Euro bumpers, and Ti conversion. I'm sure I'm going to be speechless when she's back.
    He's to be taking progress pictures of it all as she will be stripped bare to have a proper job done and to prove that she was never wrecked or in an accident.
    Pics to come when I get them.
    2008 RS4 Mugello Blue Pearl, Silver Interior
    Senior Member Two Rings AWD Addict's Avatar
    Nov 06 2013
    Livermore, CA
    What caused the body damage?
    Veteran Member Four Rings singleframe's Avatar
    Apr 25 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    That's a lotta acorns!!!!
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Oct 04 2013
    United States
    The hood needed to get replaced as it was peened up badly, the trunk lip took a good hit, and the roof saw a few. The whole upper end of the car would've needed paint and blending down.
    It made more sense to go over everything than to spend many hours trying to blend it all in.
    Oct 04 2013
    United States
    I hope to have some good assembled pictures soon.
    Veteran Member Four Rings two2's Avatar
    Jan 25 2009
    RS4
    Tri-state/CT
    are you replacing the trim for Ti conversion? if so, should of had them remove the trim before painting the car.
    Oct 04 2013
    United States
    Quote Originally Posted by two2 View Post
    I'll do that at some other point, he didn't want to remove it so I let it be.
    It's not that big of a deal to do on its own, and I have it vinyl wrapped for now.
    Oct 02 2005
    The Moon
    Not removing the trim prior to painting is a big mistake. The clear will peel in the not too distant future, there won't be enough coated right at and under the trim.
    Jan 25 2009
    RS4
    Tri-state/CT
    Quote Originally Posted by p3u View Post
    i think there is a tiny gap that will allow some spray to go further inside the edge, at least for the roof/arch trim, the door trim is another story. if it were my car i definitely would have them remove the trim before painting.. the painter didn't want to remove it because he probably knows, or realizes, it's a PITA to do..
    Oct 02 2005
    The Moon
    The last sentence is the real reason lol. You're right about the top gap, that won't cause any issues, however the bottom window trim is where the clear won't have enough of a gap to allow a proper coat. Under a year and it will be chipping or peeling.
    Oct 04 2013
    United States
    It should be noted that these pictures are of one of the stages of prep. He's going into the door sills with paint so I'm sure the door lower window trim will be removed. Also, I was speaking about the rear quarter windows he didn't want to remove.
    He took apart most of the car and its interior to do this, don't see why he would've not went that much farther.
    As the most highly recommended and used for top notch work, I trust him.
    Jan 25 2009
    RS4
    Tri-state/CT
    to remove the door trim, the entire door has to be taken apart, even the window/track iirc.. just a fyi.
    Oct 04 2013
    United States
    Well I spoke to him and he said he was able to get the job done involving the window trim-thankfully I won't have to worry anymore.
    Senior Member Three Rings cmd4's Avatar
    Jan 09 2010
    asheville
    I thought your first pic looked pretty darn good!
    RS4 mugello blue,Ti-Curing the itch
    04-Cobalt Allroad 78k 6mt- Car seat duty
    b6 s4 avant blk/blk-57k 6mt Gone
    DD -03 7.3 pwrstrk 6spd 200k and counting
    85 fj 60 lt1 and nv4500..Gone
    96-993 C4S…Gone
    78-fj40-smb350…alum tub,aussie 4spd,orion t case ,detroit locked
    97-40th fj80 on 33's and arb front
    Oct 02 2005
    The Moon
    Quote Originally Posted by JoeyManhattan View Post
    Nice to hear!
    Oct 04 2013
    United States
    Quote Originally Posted by cmd4 View Post
    That's before the damage lol
    Oct 04 2013
    United States
    First picture I have, that's my father BTW:
    Senior Member Two Rings RS4forfrank's Avatar
    Apr 27 2012
    2008 OEM+ RS4
    santa barbara california
    that's an awesome color. More pics please.
    RS44Frank/ 2007 Pearl Black RS4/ 2008 OEM+ Pearl Black RS4
