Originally Posted by
treginginco
No modifications needed. The allroad does come with a small protection plate (or others have it) that required a couple of holes being drilled for small screws. My install guy (Hardey's Motorwerks) said my AR didn't have that plate ----- so it just bolted right up.
Refreshing an old thread...
I was trying to install the Alu Kruez on my 2015 AR over the weekend and had the same issue as described below (taken from a thread in another forum):
When removing the factory stabilizer, I noted that the Allroad has a metal skid plate protecting the steering rack (and other assorted parts). The rear portion of this skid plate is attached to the factory stabilizer using bolts which screw into two threaded holes in the stabilizer. The Alu Kreuz does NOT have these holes. THIS IS SIGNIFICANT. When I phoned Eurocode regarding this, they said "Just attach the front portion of the ski plate by screwing the bolts in REALLY TIGHT, and don't worry about attaching the rear portion". I kid you not. That was their response. Tragic. Clearly, Eurocode dropped the ball. The Alu Kreuz is not 'Allroad ready'. I ended up drilling holes in the Alu Kreuz unit, but getting them in exactly the right place is no easy task. And once you DO get the holes in the right place, you're going to need the proper nuts (diameter and thread pitch) to screw the bolts into.
I also didn't have the 14 mm XZN triple square socket to remove the front OEM brace bolts, so that socket is on order.
As for the metal skid plate attachment, when I removed the OEM brace, I will use it as a template and drill two through holes in the Eurocode brace so that I can secure the back of the metal skid plate to the Eurocode brace with OEM 12 mm XZN triple square bolts. I have two (2) metric nylon locknuts in my hardware stash to secure the 12 mm XZN bolts, or else I'll tap the Eurocode brace (M8 x 1.25). However, since the Eurocode brace is "dished" at that mounting location, I'll need a stack of 8 mm washers (or 8 mm spacer) to serve as a shim(s).
As the other poster I quoted notes, the Alu Kreuz for the 2014+ B8.5 Allroad applications will need these two holes drilled to properly attach the brace to the steering rack skid plate.
