Results 1 to 29 of 29
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    Transmission Getting stuck in certain gears
    When im driving my B8 around im noticing that my transmission is getting stuck ins 2nd and 3rd gear. The revs sometimes go up all the way to 4k RPM before shifting up (and this is with normal driving). Also if im driving downhill ive noticed that my car likes to downshift and bring the revs pretty high. Am I having an issue with my tranny or no . Im out of warranty on my car, so the dealership is out of the question. Thanks guys
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Dealership transmission software update will likely solve that issue. Not uncommon with the 6AT, although when I had mine it was usually first gear which would hold.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 16 2015
    Quote Originally Posted by Project Quattro View Post
    Don't tell me they charge for this
    AKA: NathanMansoor
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Quote Originally Posted by NathanMansoor View Post
    Of course. It's still labor.
    Mar 24 2014
    YMMV. Mine was under warranty but it probably depends on your relationship with the dealer and whether or not that update is a TSB. Either way it only takes about 15 minutes so even if they charge their hourly rate it won't be that bad.
    May 16 2015
    I really dislike my dealer. I usually go to the one in Miramar cuz its the closest but they charge me for EVERYTHING and lie to me go to them and charge me so much money... I called to get my "Service Due" interval reset and wanted the charge me $65 for it..
    AKA: NathanMansoor
    2020 A4 allroad
    NH
    That's shitty. Hopefully you fill out the surveys?
    May 16 2015
    Quote Originally Posted by pierreb View Post
    What surveys
    AKA: NathanMansoor
    Mar 24 2014
    They should be emailing you a survey after every service visit... AoA mandates it.
    Sent from the Pedal Responce boardroom
    May 16 2015
    Never gotten a survey... I bought my car used and the previous owner had purchased extended warranty for 100k miles. So back in september my passanger door wouldn't lock anymore. It was at 92k at the time. I called the dealership and they said i would be covered. I drove there and talked to manny and he confirmed that ill be covered under warranty. they did the diagnosis and everything and my car was also leaking engine oil. so i got a call saying that since i didnt purchase warranty, then I would have to pay $1600 for both repairs. And if i wanted to opt out i would have to pay 2 diagnosing fees and the loaner car for a week. So i was kinda forced to pay. luckily my dad helped me with the repair costs. im still paying off his card that we charged... and on top of that, I never got a survey lol
    AKA: NathanMansoor
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Yeah, I go to the Auto Gallery and my SA ALWAYS calls me after, asking how my experience was and reminds me to fill out the survey.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    2020 A4 allroad
    NH
    Maybe find yourself a competent local indie and stop taking the car to the dealer if you have no warranty coverage. Indie won't be able to do the transmission update though I don't think.
    Mar 24 2014
    ^ that's how it should be. Varies hugely by dealer, though. Sorry you've had shitty experiences Nathan, but it sounds like Jaryd's suggestion is the way to go.
    May 16 2015
    Yeah I've been looking for a good and reliable shop around me. Only reason I went there was because they told me I'd be covered.
    AKA: NathanMansoor
    Jul 05 2015
    CT, USA
    Very occasionally my car will hold 2nd gear for way too long. I've always noticed before it gets to redline and manually shifted to 3rd myself. I'm not sure what would happen if I didn't, I'm assuming it would eventually shift at redline. There is a technical service bulletin for this problem TSB# 2029808. It says to update the transmission control module software. It only mentions the car holding 2nd gear though. Since your car holds 3rd sometimes, i suppose it could be something else.
    The downshifting down hills seems to be a feature to help keep you from riding the brakes. I've noticed on mine if you ride the brakes to maintain speed, it will start downshifting. If you still ride the brakes, it'll downshift another couple more times after a few seconds each. If you're on a steep enough & long enough hill, the revs can get pretty high. I'd say that that is probably normal.
    If you are going to get the software updated, there is a change they will charge you a diagnostic fee and then the labor to update. I went in once because my side assist light was coming on incorrectly, and the TSB said to update the software. I explained the problem and said I'd like to get my software updated to see if it fixes it. He said they would have to diagnose the problem and determine if that is the correct fix first. So in hindsight I should have tried going in and not mentioning any problem at all, and just said I want my side assist software updated. (not sure if that would have had a different end result)
    2009 A4 Prestige SOLD - 2.0T Quattro, Brilliant Black/Black
    Mods: Repairs: Pistons, Turbocharger, Timing chain+Tensioner, Oil Cooler, Water Pump, Intake Manifold, Wheel Bearing, Alternator...
    2014 S4 - Black/Black, DSG, Leather, B&O, Sport Diff, Peelers
    May 16 2015
    Quote Originally Posted by Homer_J View Post
    now that you mention it, my car does downshift when im riding the brakes. as for the part where it gets stuck in gears; i dont plan on going to the dealership for this lmao. ill just live with it i guess.
    AKA: NathanMansoor
    Sep 14 2006
    I didn't read through the posts, but there is a software update that Audi covers. Take it in, it's a known issue that's easily resolved.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    May 16 2015
    I called, they wanted to charge a diagnosing fee and a charge for the update. No thanks
    AKA: NathanMansoor
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    Either pay small now or pay bigger later. I dont know if Pure Motorsports which is around corner of Audi of San Deigo can do it, i would call them and see what they say.
    May 16 2015
    Quote Originally Posted by lx4life View Post
    That's where I'm getting my tune done! I'll give them a call, thanks
    AKA: NathanMansoor
    Mar 24 2014
    I don't know if Indy shops can do these OE software updates. I'd call another dealership near you to see if they'll do the update free... Give them your VIN, tell them you're aware that there's a service bulletin about this, and ask if they'll perform it. TSBs should be handled by the dealer for free.
    Jul 05 2015
    CT, USA
    Don't think this is true outside of warranty. Not in my experiences anyway
    May 16 2015
    The next dealer is 2 hours away from me, Mission Veijo. I dont get why miramar wont cut me some slack, the car has been serviced there since it was brand new. everything from oil changes, to turbo replacement.
    AKA: NathanMansoor
    Nov 03 2007
    Audi of San Diego has been good to work with, i never had any issues with them. I got my oil consumption fixed out of warranty by them with no issues plus got a loaner. didnt pay a cent. Mission Viejo is good also, I only bought a car from them never got my car serviced.
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    My local dealer charges 125/ item in question, unless it's under warranty. If it's a quick fix I usually end up paying about 60, if it's an engine issue its typically between 500-1000.
    As for the long shift period, my old b7 used to do that in 2-3 so I drove in tip full time for about a month then it seemed to fix itself and shifted normally after that
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    I found that just a simple adaptations reset in VCDS solved this issue for me. Worth a try if you have access to or someone with a cable.
    May 16 2015
    Quote Originally Posted by Alex1188 View Post
    can you show steps to this ?
    AKA: NathanMansoor
    Mar 10 2013
    Quote Originally Posted by TurboNate View Post
    Here ya go!
    |CURRENT|01.5 S4|
    |TOTALLED|09 B8 A4 QUATTRO|EURODYNE|FRANKENTURBO F23L|
    |PAST TURBOS|IHI JH5|PROTOTYPE BW K03 BILLET WHEEL|
    - OEM IHI K03 APR STAGE 2+ V1.0-1/4 MILE TIME [email protected](-85DA)
    May 16 2015
    You're the man!
    AKA: NathanMansoor
