Results 1 to 21 of 21
    Mar 29 2012
    SF
    Possible to cut down a coilover?
    I need to know if it's possible to cut a small amount off the rear coils. It's from a set of KW V1's for a 2013 S4. At max drop they sit higher then the fronts and the stance is thrown off. Car is sitting on 20" Vossen wheels.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Cutting will probably ruin ride quality. Why not raise the front a little?
    Love how it sits on the back... Lil too low on the front IMO
    May 17 2012
    Houston, TX
    No.
    May 14 2015
    New York
    Quote Originally Posted by inked_up415 View Post
    Not to go off topic but where did you get those side skirts?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    have you had them on long? kw/st springs settle quite a bit. My rears are maxed out to the top with a spacer and my tire is right at the lip. I wonder if they have the avant springs in the kits now. Id trade you springs, mine can dump super far. also did your car have ADS? if so did you forget to take the spacer out? that would add height to the rear.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Take a look at the rear springs...if there are "dead coils" you might be able to cut 1/2 a coil off with no ill effects. Just make sure there is still tension on the spring, otherwise you'll complete un-seat the spring. If it were me, I'd raise the front ever so slightly and call it a day. Your car looks clean and aggressive at its current height (raise the front slightly). Just my .02.
    Feb 10 2012
    B8 S4
    SF|CA
    purchase shorter springs
    B8 S4 | Black Optics | 6MT | Sport Diff | Carbon Atlas | APR Stage II | StaSiS Ohlins SL | AWE Touring | Eurocode Stage III Clutch/LWFW | Eurocode ÜSS | Eurocode Alu Kruez | Enlaes Duck tail | Deval F/R carbon diffuser | O Carbon dash surround | Valentine V1
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    Quote Originally Posted by GRUMPY-S4 View Post
    this!
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Gorgeous color, raise the front as others suggested. Never ever ever cut springs. They were engineered like that for a reason.
    Mar 29 2012
    SF
    Quote Originally Posted by suprspinner View Post
    Full Reiger carbon fiber kit. The skirts were installed not so well and some of the black sealant is showing. So they'll be replaced and these ones will be up for sale if interested. Cost $600 and will sell them for $200.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Cut springs, is it 1990 still?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I agree. Just raise the front up a little bit. Seems a little too low and is throwing off the look for me. The car looks great though! I like that bumper.
    Edit: and please get ecodes or at least ditch that orange reflector. :)
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Apr 11 2012
    Quote Originally Posted by cspcrx View Post
    LOL.
    Cut springs ride like shit (think extra bouncy)
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Must want the ricer bounce
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Apr 11 2012
    Quote Originally Posted by DGVR6 View Post
    it's kind of fun.... for about a mile.
    Aug 03 2014
    Queens
    Quote Originally Posted by will13k7 View Post
    It does look like fun lol
    In all seriousness though , I think KW sells shorter spacers or you can find a thin rubber spacer
    Previous
    May 13 2011
    2015 BMW F30
    this is why we can't have nice things : /
    | Autospeed | JHM | Pure MS
    Mar 29 2012
    SF
    My friend had asked me the question cause it was really bugging him so that's why I posted it here. Anyways, he ended up buying air ride suspension instead.
    Mar 29 2012
    SF
    Anyways, if anyone is interested in the side skirts lemme know.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Don't cut them. You will hate yourself for doing it. The Stance is fine. a little rake never hurts anyone. I think it looks good like that. Most cars are like that on purpose. Just raise the front a little. Or if your that upset with it. Just put air ride on it and you can make it do whatever you want whenever you want.
    Apr 02 2016
    Gaithersburg, MD
    Quote Originally Posted by shadycrew31 View Post
    Amen!!
