Results 1 to 4 of 4
Thread: More power
    Established Member Two Rings jesse_gabriel's Avatar
    Dec 09 2015
    california
    More power
    I have a 1.8t b6 and I thought it would be a pretty fun car at around 400 hp. I'm debating wether to do this or sell the car. What would be the most effective way to do this and ball park price? I'm sure I'm probably going to need an s4 tranny right? Any suggestions please
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Searching the forum is a great start. There is a ton of information.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    In short you will need a built engine, big turbo with all the related supporting mods (quality intercooler, exhaust work, manifold(s), diverter valve, wastegate if applicable, clutch, flywheel, etc.), solid tuning, proper fueling (pump, injectors).
    On top of that you will most likely need upgraded brakes to slow it down, and possibly some suspension work depending on how you plan on driving the car.
    This is after all the regular maintenance has been done and the wear items replaced such as control arms, tires, etc.
    If you have ~$10K minimum burning a hole in your pocket, and a secondary vehicle to get to and from work when it’s broken down/not running well, go for it. If not, a GTRS is tried and true, can yield 300awhp with proper tuning (but that is near the threshold of the capabilities of the stock rods), and will only cost a few grand for a proper setup.
    2019 SQ5 Prestige
    Dec 09 2015
    california
    Thanks a lot for the info!
