Results 1 to 4 of 4
    Apr 07 2016
    Eureka
    2004 A6 dash turn signal issues
    So this is a very interesting issue that I'm dealing with. I have a 04 A6 QUATTRO.
    So everything with the turn signals work perfectly. All the lights on the outside of the car are good and the emergency flasher is working great. JUST REPLACED WITH NEW JUST TO MAKE SURE.
    So when I indicate a left turn the relay clicks CORRECTLY, the lights on the outside of the car BLINK CORRECTLY. Also when I indicate a right turn signal light, THE SAME THING, EVERYTHING WORKS.
    The problem is the signal on the dash does not work for right or left, even when i put the flashers on, no dash turn signals work. Everything on the outside of the car indicates what i want it to. However the dash TURN SIGNALS don't show any lights. Now I have a hard time believing that both bulbs have gone bad. They are LED, NOT REALY SOMETHING THAT CAN BE CHANGED. Has anyone ever experiences this? There must be something that sends a reduced amount of power to the LED so it doesn't get to much voltage.
    Apr 18 2007
    ny
    Pull the cluster, take it apart and inspect the board for any component damage.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Apr 07 2016
    Eureka
    It all looks great!
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Sounds to me like your LEDs may be burned out.
    Did this issue just start, or has it existed since you first acquired the car?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
