Results 1 to 3 of 3
    Apr 07 2016
    Eureka
    2004 A6 Quattro dash turn signal lights not working
    So this is a very interesting issue that I'm dealing with. I have a 04 A6 QUATTRO.
    So everything with the turn signals work perfectly. All the lights on the outside of the car are good and the emergency flasher is working great. JUST REPLACED WITH NEW JUST TO MAKE SURE.
    So when I indicate a left turn the relay clicks CORRECTLY, the lights on the outside of the car BLINK CORRECTLY. Also when I indicate a right turn signal light, THE SAME THING, EVERYTHING WORKS.
    The problem is the signal on the dash does not work for right or left, even when i put the flashers on, no dash turn signals work. Everything on the outside of the car indicates what i want it to. However the dash TURN SIGNALS don't show any lights. Now I have a hard time believing that both bulbs have gone bad. They are LED, NOT REALY SOMETHING THAT CAN BE CHANGED. Has anyone ever experiences this? There must be something that sends a reduced amount of power to the LED so it doesn't get to much voltage.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    OP,
    This is the C6 section. You need to repost this in the C5 section to get better help.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Apr 07 2016
    Eureka
    Thanks. I will change locations
