Originally Posted by
koolade9
How frequent is your misfire?
Only occurs on WOT or heavy load in high gear. If I stay a part throttle, I can keep it from misfiring. Above 5k rpm, minor misfire will occur even at part throttle. At WOT misfires just climbs until it sets off DTc and blinking CEL. No other condition cause it to misfire. Idle and part FT in Bank 2 is 2.3% and 2.3%, Bank 1 is 2.3% and -5.5%.
Swapped coils and plugs. Coils were a bit old, so I opted to buy all new. I also ended up installing new plugs gapped smaller too. I even swapped banks 1 and 2 coils (new coils) after I did a compression test. Cold and dry compression test were 152 +/- 2 psi on all cylinders (had the throttle WOT during each time and cranked until needle stopped)
Injectors were cleaned and flow tested Before, 4 were dripping (#2,3 and 6,7, #6 had the lowest flow). After, all 8 had excellent spray and within 1% of each other. Test were done through 100% duty cycle, but at 43 psi. Shop will look at injector again for me.
I want to check the cylinder walls when I do a carbon clean and swap injector. If this doesn't fix it, I'm a bit stumped at what to check next. Misfire started about 8 weeks ago after doing repeated WOT runs. Car had 16k miles since SC install with no major issues before it started. Since misfires started, been babying the car and working on it. It hasn't been driven much.
