Results 1 to 37 of 37
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Dual Pulley (DA + 1327 ft) --> [email protected]
    I know this is the S4 forum, but the S5 forum rarely sees talks about speed enhancing items...
    I made plans with a buddy of mine to head out to the track tonight, as the forecast earlier this week was supposed to be mid-upper 60's temp and low humidity as a cold jet stream was predicted to dive down into FL with DA's near 100-200feet, but it never happened, and it doesn't look like it will happen again until Dec-Jan (but "possibly" this Saturday morning, we will see, but I'm not holding my breath!).
    As such, the conditions were as follows --> 75F, 67% humidity, 29.94Hg pressure, track elevation 50ft. Effective density altitude of 1327 feet, not bad, not also not ideal. Track prep was good, but got worse as the night progressed and humidity rose as temps dropped.
    Mods:
    GIAC Stage II ECU (version 2, RACE file)
    GIAC TCU file (4,500rpm launch control)
    AWE-tuning pulley
    JHM Overdrive crank pulley
    CW Pro (5-1 setting)
    aFe Pro air filter
    034Motorsports TBB
    Airbox box
    X-pipe mod
    Wheels/tires: Stock OEM 19" rotor wheels (S5), 255/35/19 PSS set to 39f/38r.
    Fuel: slightly under 1/2 tank of my usual 93/E85 mix
    Weight reduction: spare tire/jack removed.
    I'll get the slip uploaded, but I want to attempt again Saturday morning during test-n-tune where the forecast humidity may be 40% along with low 60's temps (DA closer to 400) before uploading it to the site.
    R/T .343
    60' 1.607 (<----wow!)
    330 4.726
    1/8 7.338
    MPH 95.06
    1000 9.573
    1/4 11.461
    MPH 119.56
    My best trap of the night was 119.93mph, so close to reaching that 120.xx mark! I'm happy with my 60ft time, now if the weather would just be cooler for me. It does make me currently #3 on the stock S/C 1/4mile list though.
    For reference, I ran [email protected] prior to having a dual-pulley set-up, however that was run in more favorable 368 feet density altitude.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Your running the CW and GIAC together. Interesting.
    Tom (Panzer), told me about your car and your goals to run 10's.
    Aug 09 2015
    Sarasota, FL
    Tom's a great guy, he'll be installing the first piece of my cooling: the AWE divorce cooling separator.
    I'm not getting anywhere with my tuner and writing a dual-pulley file with them backed up with projects, so I'm improvising temporarily and digging back to my N54 day's and Mike (bhvdr) for planting the seed, I went ahead and started testing the combination. So far, so good logging it the past two weeks. The only reserve I have is the rough shifting and hesitation post-shift at certain throttle settings, which can be seen in logs as timing corrections (up to 5 degrees but quickly drops back to o) that last for a few rpm in the log post-upshift that others running CW-only have mentioned in past threads. The solution would be to crank down the settings on the CW unit and reset the ecu, however I have not the opportunity to do so.
    Registered User Three Rings S4M3's Avatar
    Jul 12 2007
    B5 S4,B8 S4, E55 AMG
    Atlanta, GA
    I am about to install my crank pulley too and get it returned on e85
    Sent from my SM-G935T using Tapatalk
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Quote Originally Posted by Loe View Post
    I'm not getting anywhere with my tuner and writing a dual-pulley file so digging back to my N54 day's and Mike for planting the seed, I went ahead and started testing the combination. So far, so good logging it the past two weeks. The only reserve I have is the rough shifting at certain throttle settings, which can be seen in logs as timing corrections that last after an upshift. The solution would be to crank down the settings on the CW unit and reset the ecu.
    Sub to your AWE divorce cooling separator updates.
    would you do some IAT logging for this upgrade?
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    It looks like your plan has worked with the CW Loe.
    If you get the right conditions your time should be pretty amazing :)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by S4M3 View Post
    Let us know your results, you'll get a nice shove on the seatback with the extra TQ everywhere!
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by lowjonathan View Post
    Yes, i'll be doing tons pre & post AWE coldfront reservoir using a mix of G12 fluid + redline water wetter should see some positive results, if not exactly as good as the full AWE coldfront system, but at least better than a non-divorced system for my needs.
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by xpoweruk View Post
    short-term yes, I'm still reserved on the long-term affects of using the CW, but thats my risk (and I don't recommend anyone else using this route just yet). Knowing the sensor that is manipulates and that it still allows the ECU to bypass when needed, I don't foresee issues in terms of safety, but you never know.
    I hope the right conditions comes up soon, or it'll be a LONG year for me lol
    Nov 18 2014
    Jersey
    nice trap speed.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Jul 21 2004
    South Florida
    Nice work so far Loe. I'm guessing you have an 11.2 in you in a better DA. It'd be interesting to compare CW and non CW logs at the shift points if you ever get a chance. I dont usually log shifts that much. Good luck SAT man.
    mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice pass brotha! You need some lightweight wheels, but the pss's are hooking for sure! I think with a good da and lighter wheels, you'll crack a 11.2x @ 120.xx
    We're you getting any hesitation or weird shifting in that pass?
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by BlownOne View Post
    Will
    Both actually, particularly on the 2-3rd upshift. Less so on the 3-4th upshift. I dialed back the CW this morning prior to coming into work, seems smoother but ill have to log to make sure. Others have said it cured after they disconnected the battery for a few hours, not sure i want to go that route just yet as I hate having to reset everything.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    What is your Pump/E85 mix ratio? I'm looking to go this route.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by CELison View Post
    I keep it at a 37.7% mix.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Nice passes. Too bad on the DA. The dual pulley really does make for some killer 60' times. That's pretty impressive for no LW mods.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Feb 23 2010
    Emmaus Pa
    To clarify that's 37.7% E or 37.7% E85?
    B9 S4- EPL/AWE
    Aug 09 2015
    Sarasota, FL
    Good point, total ethanol content.
    Feb 23 2010
    Emmaus Pa
    Alright so ~7.1 Gallons of E85, rest 93. 16 Gallon Tank
    B9 S4- EPL/AWE
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    I love 1/8 trap speeds . With quattro, dual-pulley will hold its own vs faster cars, especially those that enjoy street light to street light racing in the unknown areas of Mexico.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Aug 09 2015
    Sarasota, FL
    I use this as a guide for all of my fills --> http://www.intercepteft.com/calc.html
    7.1 gallons is way too much for my fuel system. It truly depends on the conditions your car is exposed to. For instance, some have ran up to 50% without issues, mine can't do that.
    Feb 23 2010
    Emmaus Pa
    Alright. Maybe S5s have a different size fuel tank. At 16 gallons, 7.1 gallons E85 results in 37.7% total E content.
    B9 S4- EPL/AWE
    Aug 09 2015
    Sarasota, FL
    When I use the calculator (using 16.1 gallons as the total tank size) 7.1 gallons of e85 comes to 43.1% ethanol content. You have to account for pump fuel having 10% if your area contains ethanol in it (mine does).
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Damn Loe, that s5 is a monster... Car has more in it for sure. Thanks for sharing logs and these updates. Looking forward to seeing how things work out in better conditions.
    Feb 23 2010
    Emmaus Pa
    Yup. Didn't account for that.
    Thanks
    B9 S4- EPL/AWE
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Also have to take into account that most e85 is not truly e85. The station by my house is testing out at ~e74.
    2016 S6
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by AudBoost View Post
    I have an e85 tester for this reason. No one at the gas station knows when they are switching back to E85 from E70 either. It's still pretty cold in East PA
    B9 S4- EPL/AWE
    Aug 09 2015
    Sarasota, FL
    Very cool, someone got the run on video! https://m.facebook.com/story.php?sto...5&id=633159119
    ***edit nevermind, the video link isn't a shared one, or at least not on my phone without the FB app? Not sure, it may work on your phone***
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Good stuff man, in for updates
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Dec 30 2015
    Sacramento, Ca
    Well shit you might have 11.1x in that thing after you iron out he shifting issues. I know I lost .1-.2 when I had a 1-2 hangup so I would expect the same for you. I know it's more money, but you might want to hit up tony@epl for an actual stage 3 custom 93/e85 tune...how much is that 10.9x worth lol
    Will
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Nice runs, that's flying.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Apr 04 2012
    MSP
    Nice hit!
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by jran76 View Post
    Yes it definitely does, and it's noticeable on the street in terms of drivability. If you are still looking, I would actually try S4Matty's new OD pulley. Between his testings, and Primetime's track about to open up after the winter weather clears, and others like Grumpy now fully E85 on stage 2, we are going to be seeing some competitive times this year. If I do make a record run, I am willing to bet that it will be a short run because of the upcoming new items.
    Quote Originally Posted by mrmomo313 View Post
    Thanks man, and I must say you are correct about traction issues on the street. I have PSS's with less than 1000 miles on them and anything over 50% throttle my TCS kicks in hampering acceleration. I sometimes get that "steering lock" sensation (where it refuses to self-center) similar to a FWD-only powered car when accelerating briskly around a tight turn, definitely was not there when stock
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Nice run, good job
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Aug 09 2015
    Sarasota, FL
    Which one is that? I've been lucky with mine being tested in the past at 83-86% at the Citgo in Sarasota. Do you ever come down to Bradenton Motorsports with the Tampa Audi Sports club? They are wonderful people and it's always fun!
    Aug 09 2015
    Sarasota, FL
    Will
    I do agree on the .1 second loss. Earlier this year, I would occasionally get a 3-4 shift hesitation at WOT, not really a lag, but more of a "I'm not sure what I'm going to do, pause, then shift" instead of one seamless 3-4 clutch swap. I would see my 60 ft times, 330 ft times all similar, the 1/8mile and ET's same, but my 1000ft time rise (right where the 3-4 upshift happens), effectively lowering my 1/4 mile/ET by .05-.1 and .5-1mph lower. I'm hoping a TCU reflash will cure that, but I'm waiting for after my 35K service and heading to my local GIAC dealer forthe reflash and to raise my LC limitations to what GIAC describes as" beyond what you can physically reach." The descriptor sounds good in my book! My count is at 185, so I only get 15 more passes today (Saturday) before the LC limit is reached
    I've thought about contacting tony@epl, I did have his stage I which I thoroughly enjoyed. But I want to utilize the GIAC as long as I can, especially since I'm considering the B9 S5 in a year/year and a half.
    Apr 05 2005
    Tampa, FL
    Both the RaceTrac and Thortons in Westchase are both in the mid 70%. I tested fuel at RaceTrac and my friend tested the fuel at Thortons. I would love to see 83-86%. I haven't been down Bradenton yet, but a bunch of guys from ASOT usually head down that way. I am definitely going to have to make the trip now that my car is setup.
    2016 S6
