Wheel bearings will need replaced for a number of reasons, the most common being normal wear. If there is a loud metal-to-metal noise while driving, it's likely that the bearing has failed.
A simple way to check your bearing is to lift the wheel off the ground and try to move the tire back and forth, by pushing the top and bottom of the tire in. If there is play, this commonly means the wheel bearing has failed.
Grind-Be-Gone.
Fits:
Audi B5 A4 quattro 1996-2001
Jason
