Located in the wheel hub, brake drum, or rotor itself, wheel bearings support the full weight of the vehicle while allowing the wheels to rotate smoothly within a steel enclosure.
Worn bearing symptoms range from loud noises emanating from the wheel hubs to general rough ride characteristics.
These assemblies are pre-pressed here in-house for customer convenience. This takes away the most difficult aspect of changing the front wheel bearing (Having to separate the hub from the bad bearing, then pressing in the new bearing).
Get It Together.
Fits:
Audi B6 A4 2002-2005
Jason
