Results 1 to 6 of 6
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    Is your passenger side fog grille mis aligned?
    Hey guys,
    So I was installing some Hoen H11 endurance yellow fog bulbs on the car this morning. (Quick painless job by the way to swap bulbs, T25 torx head, rubber gloves and 15 minutes) and upon completion I noticed my passenger side fog grille seemed kind of off, with respect to the driver side one. See pictures below.
    Perfect Driver side:
    Crooked passenger side?:
    It almost seems like it's meant this way upon my analyzing. The driver side grille is "open" with the cooling core behind it therefore the removal of this side is as simple as reaching in and lifting each tab away from its latch point and then just pulling it away from the car. Where as the passenger side is closed and I believe needs access from behind the wheel liner or needing bumper removal to take off the grille. Which I did not do.
    Just wanted to check in with you guys if anyone can confirm this is normal or has run into the same thing and how did you fix it. I put pressure on the passenger side, tried to push and pull but it's for sure secured in place.
    Just strange that it doesn't sit against the bumper as flush as the driver side.
    Any replies or info is thanked in advance
    Apr 04 2015
    United States
    yep... Mine is.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Mine is the same way.
    2016 S6
    Jan 02 2013
    San Ramon, CA
    Very strange. Well thanks guys for clarifying. Guess I'll just leave it alone then lol.
    @rwtzero @audboost
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    I swapped out my Fog lights yesterday also & thought they seemed a bit askew. Now you have just confirmed what I was thinking! Also there were a shit load of leaves trapped behind the drivers side light blocking the inter cooler. Will make a habit of cleaning it out from now on.
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    Funny even on my B8 2010 S5 my passenger side is like that lol. When I dry the car and shammy that area with pressure it has a small bit of wobble compared to the driver side and doesn't sit flush compared to the driver side.
    Learn something new everyday, funny though. I bought maybe a clip was broke & didn't want to mess with it and break another haha.
