Earlier this week I had my car setup to run EPL's stage 2 E85 tune which consisted of having a CTS pulley, Continental Flex Fuel sensor, Fuel-It Bluetooth analyzer, and Autotech HPFP upgrade installed. Tony requires that his E85 tune be run on at minimum of E70. As E85 blends can differ throughout the year and from station to station it is always a good idea to test what is exactly being pumped into your gas tank. In my search for options I chose to go with a solution that I was familiar with from my previous car. I chose to go with a Bluetooth option that connects to an app on my phone versus having a gauge installed specifically to read the analyzer or buying a P3 gauge and connecting it to the analyzer.
http://www.fuel-it.biz/ethanol-analyzer-options/
Following pictures provided by andthen of his setup I chose to install the Flex Fuel sensor on the heat shield of my CTS intake. However, it was decided to move the sensor to the cold side of the heat shield. In the event there is a fuel leakage fuel could be directed away from the hot engine as much as possible. The return fuel line was then routed under the CTS intake/filter back to the OEM connection. About 8" to 10" inches of additional fuel hose was needed to complete the connection. Quick disconnect fittings were used to attach the fuel line to the Flex Fuel sensor.
The wiring for the Fuel-It Bluetooth Analyzer was routed following the lines to the ECU box but it was decided to run the power line to the power terminal located in the center of the cowl. A quick disconnect fitting was also used in the case analyzer need to be temporarily disconnected.
The app is available for iOS and Android. There is no need to pair your phone with the Bluetooth analyzer as the app does it for you each time it is launched. Once connected to the analyzer it shows ethanol content and fuel temperature if desired.
