Results 1 to 40 of 60
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Oversized crank pulley
    Hi guys
    Just wanted to share my latest project.
    Myself and another have invested a lot of time in this pulley.This pulley is now our 3rd style/overall size,and I must say it performs awesome! It is larger than what is currently made for our platform and we are able to 1.5psi more without really much increased IAT'S on his car..
    Let me know your thoughts. It was a lot of work and money to undertake for just 2 guys,mainly because we had to buy so much aluminum stock to get the price down.We are sending our pulleys out for hard anodizing to ensure it lasts a long long time.
    Sent from my SM-G900W8 using Tapatalk
    Senior Member Three Rings usmc1994's Avatar
    Nov 11 2013
    2014 Audi S4, 2014 Audi A4, 2005 1/2 A4
    Home
    Wow that's really nice, what times will is support, any dyno runs ect?
    Apr Stage 2, Stasis touring suspension, 20x9 Stance Wheels SC-8 with Michelin Pilots, AWE exhaust 102mm tips Vag Com, Alu Kreuz, Awe Boost Gauge
    Senior Member Two Rings A.Bruno6's Avatar
    Jun 02 2015
    Ontario Canada
    This is glorious! Whats the final diameter or circumference on this pulley? And what alloy of aluminum stock was used?
    Great work guys, cheers!
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    1.5 psi more that what? Stock or JHM oversized crank pulley? Do you have any logs you can share?
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by jran76 View Post
    1.5 over the current oversized ones..We did some logging in The car it's in..I will get him to email me the logs.
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    how much? looks likes an awesome piece
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by s4matty View Post
    What supercharger pulley was being used in conjunction with it?
    Aug 15 2015
    2 feet
    Niagara canada
    He has the cts charger pulley...I'm putting mine on and running with stock blower pulley..It's the same final drive as a existing dual pulley set up with just my crank pulley with Oem blower pulley.Im putting mine on as we speak.
    Jul 21 2004
    South Florida
    Nice work Matty. I'm looking forward to your results. I assume the balance is the same as OEM?
    I may need to contact you about this. I have a CNC shop in town that is planning to help but I need to make a smaller SC pulley for my car and mine uses a 4 bolt SC pulley now for 2016 instead of your friction fit one. I'm not sure how much this is going to cost though.
    What grade aluminum alloy did you use?
    BTW, did you put a thermal dispersant coating on your SC? Did it make any difference?
    Mike
    2018 Audi S5
    Gone-
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by bhvrdr View Post
    Mike
    Hey Mike
    Send me a pm and we can hopefully make something work (or help at least)
    I used 6061T6 aircraft aluminum.Also I did cnc ballance the pulley.I do have a 3rd pulley if your interested in it?lol
    Jul 21 2004
    South Florida
    Hey Mike
    Thanks Mattty. I'll PM you.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Good stuff, 182mm lower with CTS upper? You a 195?
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Cool. Thanks. Makes sense.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Nice work brotha!
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    looks like coolant for supercharger is gone, why ?
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Aug 15 2015
    2 feet
    Niagara canada
    Well just went for a drive..I'm hitting 22psi on the podi,before it was 19ish
    .Not saying that's the true boost,but it is showing a gain.I have the apr charger pulley on atm with it..I just did 1 quick pull because I'm not finished my meth fir blower,I'm just spraying in throttle body and intake tube..Hopefully I get my new spray nozzles tmrw so I can do some logging.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Good stuff man, keep it coming
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Subscribed
    2007 RS4
    2000 B5 S4 stage 3
    Dec 30 2015
    Sacramento, Ca
    Remember that you should have lost boost pressure since you ported the blower so that means it's definitely spinning faster!
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by BlownOne View Post
    This is true!
    Charger sure sounds crazy
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    nice work
    sub for more
    Jun 12 2015
    CA
    Throw that bad boy on a scale!
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Everything about this says win! Curious on the method you're using to control bleed boost
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I'm confused. Is this viable for a true dual pulley setup, or does it essentially negate the need to get both blower/OD pullies?
    I'd be interested but don't want to spin my charger to 50k rpm considering I already have a CTS pulley on haha
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Nov 20 2014
    New York
    Quote Originally Posted by Hofahome View Post
    Viable for dual pulley set up (I.e. This OD crank pulley and your existing CTS charger pulley) and also viable for stage 2 if you don't want you replace the charger pulley you can replace your crank pulley with this one and it spins the blower as fast as the smaller charger pulley.
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by UkuRiSh View Post
    I had another post going on that subject.Anyways my coolers got damaged and instead of paying the same price ashown a used blower I decided to try out spraying water/meth directly into the blower in 4 places..I do not have my new nozzles yet so I can't test it out yet..
    Established Member Two Rings artz66's Avatar
    Jan 04 2016
    Illinois
    Def interested and going to follow this.
    Aug 15 2015
    2 feet
    Niagara canada
    I made this with a plan to just use on a friends car and keep his factory charger pulley while still maintaining the same drive as the current duel pulley set up..I'm driving with this crank pulley and my apr blower pulley..It's not 50k rpm.lol
    There us a big improvement in the 2
    1500-5000rpm range..
    Jan 26 2015
    CO
    Quote Originally Posted by sonic32 View Post
    10-4. Subbed.
    Jul 01 2015
    NS Canada
    Im interested in this as well
    Established Member Two Rings Tod's Avatar
    Jan 13 2016
    Nw burbs Chicago
    Sub'd... nice work op!!!!
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    2012 Prestige, TI package b8 S4
    Past fun,
    2008 SRT8 Jeep pwr 440 Blown by Vortech
    1996 Eclipse GSX bunch of crap
    1996 Slp SS 383 Blown by Vortech
    Established Member Two Rings Danny2323's Avatar
    Mar 30 2015
    Cincinnati
    Nice work! Can you share the diameter?
    2014 S4 DSG | Monsoon Grey | B&O | Nav | Sports Diff | Nappa Leather | Carbon Atlas Trim w/ oCarbon Dash | LED Interior w/ Red Ambient Footwells | LED Reverse & Turn Signals | Alu Kreuz | CR-15 Strut Brace | Carbon Mirrors | Llumar 50% Ceramic Tint | Trim Blacked-Out | M'Autolite LED Fogs | Eurocode Drivetrain Insert Kit | Ultra Racing Strut Brace | H&R Sways & MOOG ends | Bilstein PSS10 | SPC adj UCA | HRE FF01 IPA | PSS 275/35/19
    Dec 30 2015
    Sacramento, Ca
    This is true!
    I'm jealous! My little stage 1 needs some more whine...
    Jul 29 2009
    Quote Originally Posted by Danny2323 View Post
    The math would look like:
    Stage 2
    Stock Crank Pulley = 162.179
    Aftermarket S/C Pulley = 57.56
    Ratio: 2.82
    Dual Pulley
    JHM Crank Pulley = 179
    Ratio: 3.11
    Single Crank Pulley
    S4matty's Crank... = 196+
    Stock S/C Pulley = 63.25
    Ratio: 3.10
    Jan 29 2013
    2011 Q5 2.0, 124" HD Dyna Wide Glide
    Philadelphia, PA
    I want one, you going to produce these?
    2010 Phantom Black S4 Prestige DSG, Silver Nappa, APR stage 1, Milltek Non-res, AG M510s, BC Racing BR series coilovers
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by jayts View Post
    I am thinking about it?
    I'm going to throw a couple on ebay and see what happens..
    Jan 29 2013
    Philadelphia, PA
    Do you know what rpm it spins the supercharger to?
    Account Suspended Three Rings
    Oct 15 2015
    Held / seen in person. Dynamite looking, light / well made product!
    Aug 09 2015
    Sarasota, FL
    hoping this is available in the fall, I may look into this option to push the stock S/C further. Keep up the awesome development man!
    Nov 20 2014
    New York
    If it doesn't overspin the blower with the smallest charger pulley available I'm interested as well. I think $500 for a crank pulley is a little too much and then there's the other one for $1000
