I am pulling motor, trans, subframe of a 2003 Alload.
Is there a practical way to 'save' the AC charge (not having to disconnect/bleed and potential ruin the AC system)?
I want the entire front of the car (radiator support) off the car.
I am not sure if I can 'swing' the AC condenser just out of the way (after unbolting from radiator)?
But then still have to also remove the AC compressor (on driver side), and lines going to/from the compressor?
If disconnecting (would prefer), is there a way to 'protect' the "drier" and other components?
How long can a system be open and exposed to humidity before it is damaged and needs to be replace (drier, other components?)?
