Results 1 to 4 of 4
    Established Member Two Rings verstappen's Avatar
    May 05 2014
    B5 S4, B6 S4, B8.5 A4, 11 Audi Q5
    Phoenix
    P1649 and P1650 After going Stage 3
    Well I finally finished my Stage 3 project last night, the car started and seems to idle fine... Though I just got those two codes and I have no idea wtf happened...
    Powertrain data bus p1649 missing message from abs controller
    Powertrain data bus p1650 missing message from instrument cluster
    I got an ECU with a "base" tune for my hardware just to get the car moving while I have Daz tune my car on E85
    Will this codes be a result of using this ECU?
    Thanks everyone for any input.
    UPDATE: fixed, someone told me how to fix this
    With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
    -Ayrton Senna
    Jul 20 2011
    Providence - RI
    Quote Originally Posted by verstappen View Post
    Mind sharing how you fixed this? I am encountering the same problem, car was tuned b the late DAZ :(
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by Samataras View Post
    You have to recode the ECU through VCDS
    Jul 04 2012
    Woodbridge, VA
    http://s4wiki.com/wiki/Cluster_recode
    http://s4wiki.com/wiki/Anti-lock_braking_system
